Question about Samsung HT-DB600 System
After a while the sound goes off and I have to turn the power off and then back on to get sound. Happens very often sometimes after being on for only a few minutes. Thanks
    Brigadier General:
  • 8,546 Answers
Is it getting hot?
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 19, 2011
How can I fix my television?
Please consult some local TV tech.
Aug 04, 2015 | Televison & Video
Power
Either a loose/bad power cable or the backlight is failing.
Jan 30, 2018 | Sony SDM-HS95 19" LCD Monitor
Power
Check for a loose power cord on the back of the monitor (quite common).
Jan 29, 2018 | Sony SDM-HS95 19" LCD Monitor
My amp cuts in and out. It happens in the cold,
CHECK THE POWER CABLES FOR THE AMPLIFIER THE BATERIE CABLE AND GROUND SOMETIMES THIS CABLE THE GROUND GIVES THAT TIPE OF PROBLEM
Feb 10, 2010 | Sony Car Audio & Video
Set turns on and then goes off sometimes it will go back on sometimes, sometimes not. Makes a clicking sound when it happens. Happens whether the set has been on a while or not. model is vs-60801 made in...
that is an old sob but if it is projection then check the power butten on the tv might be stuck in or the remote might be sticking or check the battery that is suposed to save the memery in the tv
Jul 12, 2009 | Televison & Video
Intermittently all power lost after attempting to start
sounds like you need to clean the terminals on the battery and/or need to replace the battery cables, check both ends of where the cables attatch to the battery clamps, if they look discolored, melted or corroded in any way , replace them.
Jun 30, 2009 | 2001 Chevrolet Silverado 2500HD
Viewsonic N3000w LCD TV randomly shuts off...
It seems that the power fails quite often with this one burning the Inverter boards transformers. OZ960G chip may not be broken, so try getting a new power from somewhere. Measure the transformers. suppose to be somewhat 5 ohms. tolerance is +-1.5 ohm. of more, replace.
Nov 21, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Samsung HT-DB600 System Logo
48 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
