Question about Kodak ESP 7250 All-in-One InkJet Printer
ERROR CODE 3550 TOP TRAY JAMMED HAPPENS EVERY TIME
To unjamm your printer unplug the printer or just shut it down and re-start it, it will atomatically unjam itself. it that dont work then there lift the scanner bed and look where the inks is and see if there is paper lodge inside, most of the time its the small paper or an envelope that will cause this problem. hope this helps
cw, fl
Posted on Apr 09, 2011
Cannot clear error code 3523 for Kodak ESP 9200 Series all in one printer. Have followed all instructions per Kodak online
Had the same problem error 3523 that would not clear. Tried Kodak support with no results so took matters into my own hands.
Noticed the top tray seemed jammed into the printer. Tried pulling it out but it seemed locked. Flipped the printer over, removed 8 screws, 4 metal plates.
Removed bottom tray, set aside. Remove 3 screws for plastic bracket that holds top tray. Move bracket over, be careful not to damage wires. Remove top tray and reinstall so that it is in extended position. There is two notched in the side of the top tray. Extend so that catch is in back notch.
Reassemble everything in reverse order. Take care that the top tray does not slide into the printer when you turn the printer over. It did for me the first time that the tray jammed again.
Replug everything and startup the printer with top tray extended past bottom tray. The printer will tell you that top tray is jammed, push top tray flush with bottom tray.
Printer now works. Don't know why tray jams in the first place but this solution can keep you from scrapping printer or paying for service.
Very disappointed with Kodak printer. Obviously printers were not their core business and they paid a sub-contractor to build these products for them. My next printer will be an HP.
Jul 24, 2011 | Kodak ESP5250 All-In-One InkJet Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Xerox 7300 paper jam A 10 error code jam telling me to open top tray and I've looked at the machine inside out and cannot find any scraps of paper or any location where there is any traces of paper being...
There is most likely a small piece of paper in the rollers take out Tonor and any parts that will come out with out having to use any tools. then spray with a can of air in all the rollers.
Chris Thrash
B52Computers
Jan 10, 2011 | Xerox Phaser 7300DN Laser Printer
HP Laserjet 3550 Fuser Jam Error 13.20 Had it in
You need to ask them to change the fuser..The fuser is the part of the printer that actually melts the toner onto the page. Here is a website that gives you more info on the fuser so they can't B.S. you anymore..either the fuser works or it doesn't..
http://www.theofficeguide.com/toner-cartridges/faq2.html
Please rate this solution thanks.
Mar 25, 2009 | HP Color Laserjet 3550 Printer
Paperjam tray 1 error code 201.52
If you remove tray 1, is there a jam? When the printer is starting to print, does it sound like it is trying to pick up paper from the tray a few times, and then changes to the jam error? If so, then the pickup rollers are worn. You can confirm this by removing tray 1 and feeling the rollers which are located in the top of the tray in the front. If they feel smooth, then they need to be replaced.
Feb 22, 2009 | IBM Infoprint 1572n Laser Printer
Clp 310 laser printer can not seem to properly grab the paper from the tray and causes paper jam error. There is a small spring loaded platform at the top end of the paper tray that seems to push the paper...
The pickup roller is loaded with paper dust. You can try cleaning it with alcohol and a swab, but to clean all the rollers in the paper path, get some cleaning sheets from an office supply store. They are sticky on both sides. Run it through a couple of times.
Apr 16, 2017 | Office Equipment & Supplies
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Paper jammed problem 13.05.00 JAM INSIDE TOP COVER
It happens form both: manual feed and tray... sensors don't look misplaced.
Nov 19, 2007 | HP LaserJet 2420 Printer
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
Kodak ESP 7250 All-in-One InkJet Printer Logo
1,624 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
