Question about KitchenAid Ovens
I have a kitchen aid cooktop model kgcg260s and the ignition wires have worn out and i have to light the stove with lighters. where can i buy the igbition wires?
SOURCE: error code on the electronic
Error code F2-E0 is for a shorted touch pad. Get more info on appliance parts and error codes.
Posted on Apr 08, 2008
vanni7
  • 163 Answers
SOURCE: broken stovetop
Hi!!! With my experience some of them glass tops are very expensive check everywhere before you buy it and the labor to install one is high also.Good luck..
Posted on Jan 03, 2009
  • 327 Answers
SOURCE: kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
Posted on May 26, 2010
espressonist
  • 1711 Answers
SOURCE: Hi, I need to know
No the burner have no ingiter ither piezo or electric just the gill and oven as you mention.
Burners need external light however they do have thermocouple protection when the fire goes out for safety.
Posted on Sep 17, 2010
  • 552 Answers
SOURCE: remove oven door on kitchen
Click on the link below to watch a video that explains how to remove the door on most modern ranges.
http://www.appliancerepairlesson.com/2011/01/22/oven-door_diy-oven-repair-help-101/
Posted on Mar 06, 2011
Maytag mgs5870adb range-gas runs, igniter does not click on any of the 4 burners. all the rest of the oven works
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Ovens
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
My igniter on the cooker doesn't work, it doesn't click or make any sound
heatman101
May 17, 2011 | Ovens
The gas stove will not turn on
heatman101
May 09, 2011 | Ovens
The electronic ignition on my chef cooktop no longer works. Can I fix it myself?
heatman101
Apr 27, 2011 | Ovens
Nothing happens with the ignition, no spark at all. I now have to light hob with a match
heatman101
Sep 16, 2010 | Smeg S300X Electric Single Oven
I have a whirlpool gas stove, the bake or broil will not light.
Check to see if the electric ignitors are connected at the ignition module, located under the top surface panel. It is possible that the wire(s) that go to the oven ignitors has burned off or become disconnected from the main spark module,
It is also possible that the electrodes have failed and need to be replaced. These are the two (2) devices that produce the spark (and make the clicking sound) inside the oven compartment.
If those are OK, then check the thermostat, as it could be faulty and preventing the oven from functioning.
If you can smell gas when attempting to turn the oven (bake or broil) then the valves are good, if you don't smell any gas, the gas supply valves (one for each bake and broil tubes) need to be checked.
You might also try lighting the oven manually with a long match or grill lighter to rule out faulty gas supply valves or a faulty thermostat, which if you can manually light the oven, it would prove that the ignitors must have failed.
Here's the exploded line drawings for your stove along with the parts list, just click on each section to see the parts. You can order replacement parts from them as well.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=gw395lepb02&pop=flush
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Ovens
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Ovens Logo
242 people viewed this question
Top KitchenAid Ovens Experts
ashburton
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
