Question about JVC Everio GZ-MG20 Camcorder
High speed USB required?
Hello,my computer has standard USB ports. When I try to download the camera it hangs up on the "USB Connection" icon on the camera screen.Does the Everio require a high speed USB to interface with the computer?
    Sergeant:
  • 234 Answers
Install every software and reinstall it properly without error! this problem does not came!
Posted on Aug 02, 2008
Ultra SuperSpeed USB
usb speeds b> A USB, or Universal Serial Bus, is the brainchild of Intel developer Ajay Bhatt. USB is useful for transmitting data and power to devices. USB cables are widely used in 2010 to connect computers to such devices as printers, cameras and flash drives. While the USB port was initially developed for computers, it has become standard for video game consoles, smart phones, PDAs; it can also function as power cords for these devices.
Unit Load Capacity
USB comes in 1.0, 2.0 and 3.0 versions. Each provides between 4.75 and 5.25 volts (V) of power that travels between one wired line. Various devices may draw this amount of power from that single, wired line. A maximum of five unit loads can be drawn from a USB 2.0 port, however six unit loads can be drawn from a USB 3.0 port, making it capable of delivering more power to devices. USB devices are configured to support a minimum of 100 milliamps (mA) times the number of powered ports it contains (200mA for one port, 300mA for two ports, etc.). b> Charging Devices b> Many devices can draw power to recharge their batteries or can function off of power currents running through a USB port cord. Superspeed USB ports run off a 3.0 platform and optimize power usage to provide the minimum amount of energy the device needs to recharge or run. New powering modes allow USB ports to supply power and communication (data transfer) concurrently. A USB Charging Downstream Port can supply up to 1.5 amps (A) at low-bandwidth transfer rates and 900mA at high bandwidth rates. A portable device such as a phone or PDA can draw up to 1.8 A from a Dedicated Charging Port on a USB 2.0 or higher device. In 2009, major cell phone manufacturers like Nokia, Motorola and Samsung agreed upon a standard, universal micro-USB charger for all their phones. In time, this will eliminate the need for manufacturers to provide charging cables with their phones. This micro-USB device has been adopted by the International Telecommunication Union as its universal mobile phone charger solution. When a device requires more power than can be delivered by a single USB port, that device may be charged with a multi-ported USB. External hard drives, for example, can be powered by a USB cable that connects to an external power supply on one end and to a device on the other. b> Powered USB b> A powered USB is a self-powered USB that uses additional power lines than standard USB ports to deliver more electrical current to a device. It uses four extra pins to supply 6 A at either 5 V, 12 V or 24 V to attached devices. Powered USBs are used to power retail devices like barcode scanners, printers, pin pads and signature capture devices. These USBs consist of two ports: a top one which accepts a USB cable and a bottom one which accepts a power cord. The powered USB allows devices to draw more power from a USB and not require an external power source to operate.
USB Power Options
b> According to Everythingusb.com, the Universal Serial Bus (USB) is a concept that was originally designed as a connection for smartphones to computers in the 1990s. Since then, the USB has evolved from the older USB 1.0 and 2.0 designs to the faster USB 3.0 model, which is also called the "Superspeed USB." A benefit of USB is that it can be used to power devices without requiring any additional power cables or plug packs.
Low-Power USB
Low-power USB devices typically consume 100 milliampere or less from the USB bus. This is called a single-load unit. USB 1.0 and 2.0 devices have a single-load unit of 100 milliampere, and for the newer USB 3.0, the single-load unit is redefined to 150 milliampere. Low-power USB devices can be plugged into any USB host or hub port. Low power bus powered devices use the so-called "V bus" pin to draw its power and run on a voltage of between 4.40 volts up to 5.25 volts. A low drop-out regulator is required for most 3.3 volt devices. b> High-Power USB b> High-power USB 2.0 devices consume between 101 milliampere and 500 milliampere (1 to 5 load units) to run on. USB 3.0 supports power consumption of up to 900 milliampere (6 load units). These devices can be plugged in to any USB port, but if you are using a USB hub, the device will only be able to draw 100 milliampere unless the hub is self-powered. High-power USB devices run on a minimum of 4.40 volts. b> Self-Powered USB b> Two types of self powered USB devices exist: true self-powered devices that rely completely on their own power supply, and hybrid self-powered devices that also draw some current from the USB bus. Hybrid self-powered USB devices typically draw up to one load unit from the bus and use their own external source for the rest of their power. Most of these devices have a safety feature to ensure that they don't try to draw more power from the bus, should the external source fail. High Speed USB Port Since 2002, Microsoft has supported high-speed USB ports in the Windows XP operating system. Prior to 2002, computers and operating systems used the USB 1.1 standard, with its 12Mbps maximum data transfer rates. USB 2.0, also known as "Hi-Speed," pushes the maximum data transfer speed to 480Mbps. To take advantage of the higher speeds, you'll need to install a USB 2.0 card in your computer. In most cases, desktop users will need to install an internal card, while laptop users with PC Card or ExpressCard slots may install external cards.
Purchase an internal USB card or internal USB drive bay. Shut down your computer. Remove all cables and peripheral devices. Remove the left side panel (when facing the front of the case). Remove any screws or adjust any latches. The method of removing your side panel will vary according to the type of case you have. If you are unsure of how to remove your side panel, see your case or computer documentation. Attach the anti-static wrist bracelet's clip to a metal object. Strap the bracelet to your wrist. Locate an empty card slot. Remove the card slot cover by unscrewing the screw and lifting the cover, if applicable. Line up the hardware with the slot to ensure that you are inserting it in the correct direction. Insert the card into the slot until you hear a click. Do not force the card. Remove it if you're having problems. Then line up the card with the slot again and try to insert it again. Secure the card into the slot with the slot cover screw you removed earlier. Replace the side panel. Screw in any screws you removed earlier. Attach all cables and peripheral devices to your computer. Restart the computer. Windows will automatically detect your new high-speed USB port. b> Install an External Card b> Turn on your computer. Locate an available PC Card or ExpressCard slot. Insert the card into the slot. The card will click when seated. Allow your operating system time to detect the high-speed USB port and to install the drivers required. Hope this helps.
b>
Oct 06, 2012 | Ultra Products Ultra U12-40528 SuperSpeed...
Tip
How to connect an iPod to a computer connection
<p>The iPod is one of the world's most popular MP3 players because of its ease of use. You can simply drag and drop video and audio files from your computer to the device to your collection on-the-go media to expand. The process of establishing this connection with your computer is easy, and maker of the iPod, Apple only requires that the freedom of the media management program, iTunes downloads to begin adding audio and video on your iPod. <br /> <p><br /> <p>1. Identify your hardware. If you use a computer with a USB 2.0 port, then you have it easier because all you have to do is plug in your hardware. If you are using an older computer (usually with an operating system to Windows 2000), then you have a USB 2.0 port, in which case you should consider using a FireWire or USB 1.1. If you do not have FireWire or USB 1.1, you need a card or adapter. <br /> <p><br /> <p>2. Identify your iPod. Fifth-generation iPods or later can be connected using standard FireWire adapter cable option, but otherwise requires USB 2.0 ports. You can also use standard iPod USB 1.1 ports, but it requires an adapter. The Nano and Shuffle models can only connect via USB ports. <br /> <p><br /> <p>3. Connect the iPod cable that you use on your iPod. The larger end of the cable should fit in the bottom of your iPod, whether it is a standard FireWire cable or dock to the USB 2.0 connection. <br /> <p><br /> <p>4. Connect the other end of the cable to the designated location. For USB users, this will be a USB port on your computer. If you use FireWire, and connect it to four or six-pin FireWire is not. <br /> <p><br /> <p>5. Download and install iTunes if you do not have the software. It is a free program your iPod. If you had installed before establishing the connection, it will open and audio / visual files or on their own. After transferring to your iPod files to load or eject. <br />
on Aug 09, 2011 | Apple iPod touch
Sony dsc s650 no disc how can i install it
DSC-S650 is plug and play digital camera, connect it in USB port of computer, Windows will detect it and install required drivers automatically, you will see Device Ready to use message then go to my computer and click on Mass Storage icon click it to copy pictures.
Nov 11, 2010 | Sony Cyber-shot DSC-S650 Digital Camera
When uploading pictures from my cameras SD card the computer suggests using a hi-speed USB port. I have tried the other ports and it tells me the same thing. Which port is the High speed? Dell Dimension...
you have no high speed ports installed on your computer. what you have is USB 1.0. you can however purchase a high speed USB pci card (usb 2.0) and install it in your computer to get faster transfer speeds.
Jun 11, 2010 | Dell Dimension 3000 PC Desktop
Xp computer say camera is a high speed device and
This means that your camera is a USB 2.0 device, but you connected it to a (slower) USB 1.1 port.
Usually, this is only a hint and you should still be able to download images, albeit rather slow.
To fix this you should first try to connect the camera directly to one of the USB ports at the rear side of your computer and see if this fixes the problem. If so, there either is some problem with the front side USB port or you were using a USB 1.1 hub.
If you still get a warning, your computer obviously is equipped with a USB 1.1 interface only. You could add USB 2.0 support by installing a USB 2.0 card like this.
Mar 21, 2010 | Polaroid i1035 Digital Camera
What is the version of the usb port on a compaq presario 1200
Hi again, after extensively searching I believe your Laptop has a USB version 2.0.
Most PC's manufactured before 2001 were USB 1.0 and USB 1.1.
The Spec Guides for your PC indicate 2002 was the year of manufacture.
USB 2.0 is a faster USB connection than version 1.0 or 1.1. You might have trouble connecting devices that are USB 2.0 (which all new devices are now - since 2001).
To double check, use your Device Manager on the PC to look up the USB device and see what is written.
If you are using XP then do the following:
  1. Click Start
  2. Click Settings
  3. Click Control Panel
  4. In the Control Panel double-click the Systems icon.
  5. In the System Properties window click the Hardware tab.
  6. In the Hardware tab click the Device Manager button and you will see a list of devices.
  7. Click the + button next to the word the Universal Serial Bus controllers.
If it is USB 2.0 then it should say something like USB Enhanced or USB High Speed, this means it is USB 2.0 compatible.
I hope this helps. Please rate. Regards,
Feb 12, 2010 | Compaq Presario 1200 Notebook
Ipod wont show up on itunes
When you have a high speed device like the ipod plugged into a non high speed usb hub, all that means is that it will take the ipod about twenty times longer to load up under itunes then it will using a high speed port. Try connecting the ipod to a different usb port and see if that one is a high speed port (if it is, it will most likely have 2.0 written beside it, and if it does not have it, when you plug it in, it will tell you if it is a non high speed usb port. The same message should pop up. Try all of the usb ports on your computer. You should have at least 1 high speed port.
Nov 08, 2008 | Apple iPod classic MP3 Player
Hanging problem
ya u are rite connect the cable thr will show that mtp connected then transfer music but is it hanged on than this means ur usb port has problem than try to use different usb port...make it sure u are using rear usb port of ur pc.....hanging problem is only due to breakage in transfer of data that is only due to low usb port...i have same problem i always connect my media player in front usb port of pc then i got to know that it has low speed than i connect it to rear of usb port in my pc that is high speed port than it worked smoothly
Sep 02, 2008 | Samsung YP-K5JAB MP3 Player
The flash drive purchased doesnot work when pjugged into the usb port on my desk top but it work on my lap top? How do I get it to work on my desk top
Hello claponte
FIRST, THE HARDWARE SIDE:
If you just purchased your flash drive, then it is using the USB 2.0 (high speed) standard. Prior to that were USB version 1.1 and, before that, USB 1.0 standards.
USB 2.0 devices will still work when plugged into USB 1.1 ports - just at a reduced speed)
However, computers w/ USB 1.0 ports cannot properly detect USB 2.0 devices. On those computers, you'd need to install a USB 2.0 expansion card in order to add USB 2.0 functionality to the computer.
SECOND, THE SOFTWARE (DRIVERS) SIDE:
On the software side, USB devices are "plug-and-play" on Windows XP & Vista systems. This means they do not require special drivers or installation for them to work properly. The drivers needed for them to operate are already built into the operating system.
However on operating systems prior to Windows XP (Windows ME, Windows 98SE, Windows 98...) drivers are needed for USB devices to be detected properly.
These are two possible reasons why your flash drives don't work on your desktop computer.
(01) The computer is an older one using USB 1.0 technology
(02) The operating system is pre-Windows XP
Another possibility is (if your computer USB ports are at least 1.1 standard and your operating system is at least Windows XP) there is an issue w/ the USB ports on your desktop computer. This could be a hardware or a software issue still.
Please, let us know if that's the case and we'll help you to trouble-shoot the issue.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
DSC-1300
Your problem has been addressed by microsoft itself. and it is available at the following link. http://support.microsoft.com/kb/927836 If you have the manual refer to it and find out the USB version it requires and See the BIOS setting for USB.(High speed/Full speed) Some cameras only support USB 1.1 it will not work with other high speed USB. this can be modified through some BIOS settings for e.g. "USB 1.1/USB 1.0 comaptibility mode -> Enabled" Also make sure that you installed the latest drivers for your USB ports.
Sep 27, 2007 | Apex Digital Digitrex DSC-1300 Digital...
JVC Everio GZ-MG20 Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
