Question about LG PHILIPS LP156WH1(TL)(A3) COMPATIBLE LAPTOP LCD SCREEN 156 WXGA HD GLOSSY CCFL (654367710340)
The small white connector that attaches to the motherboard from the screen (the one that has two leads going to the screen and two to an led mounted to the left of the keyboard) fell apart when being removed. The screen is cracked and being replaced. What is the pinout for this small connector? The actual connectors are still attached to the wires but the white holder is broke. I can reattach the wires to the pins but don't know which one goes where. In the repair manual, this is called the webcam module cable.
  • 9 more comments
  • thomason845 Mar 19, 2011
    No that is not the one. The connector I am talking about attaches to the motherboard under the keyboard. It has two leads that go to the screen assembly and two that go to an led to the left of the keyboard. In the repair manuals steps for replacing the screen, this connection is labeled 'webcam module cable'. I assume the led to let the user know the webcam is on.
    I can't tell if my reply to your solution went through or not.
  • thomason845 Mar 20, 2011
    I will do that after I get home.
    Thanks
    The only picture I have is on page 58 of the repair manual in this pdf filehttp://h10032.www1.hp.com/ctg/Manual/c01...
    This photo shows the leads going to the webcam (step 3, location 4) but not the associated LED. The socket and plug are 4 pin and I have 4 wires. Just need to figure out where they go.
    Thank you for responding. I have to put in a long day today at work and it will be late tonight before I can take another look at this laptop. I will also try to get the motherboard model number before I contact you again.
  • thomason845 Mar 21, 2011
    I believe the motherboard # is 578228-001. The leads from the webcam are both black. From the LED, one lead is red and the other black. I have not been able to find a schematic of the MB.
    model: G60-535DX
    ser #: 2CE9470B5N
    prod #: VM085UA#ABA
    Your correct. The plastic that held the leads broke and I need to know where the webcam and LED leads attach to the socket. The connectors are still on the ends of the leads so I can slip them on the socket pins if I know where each one goes.
  • thomason845 Mar 22, 2011
    A good picture of an intact connector would be great but I don't have one. Any way to get one that you know of? Any way to get the pinout of the socket?
    How do I include a photo in a message here?
    Here are the photos of the socket and leads. The black leads go to the camera. The red and black to the LED.
    I can't get a better photo then what I have sent you. Camera on phone will not focus that close. I have been searching for more info myself and it appears to me that the leads from the camera connect to the "bottom" two pins (the ones toward the front of the laptop). I THINK the red LED lead connects to the top pin with the LED black led connecting to the 3rd from the bottom. I looked (need a magnifying glass) but could not see any indications of + or - connections. I have not removed the PCB completely so I could be missing something.
  • 4,889 Answers
Id di not understand exactly which cable are you talking about. Can you get me an image?
Posted on Mar 20, 2011
  • 8 more comments
  • eagle338
    eagle338 Mar 20, 2011
    Surething. No problem at all
  • eagle338
    Ok. Now I got the idea. But I cannot get an image of the connector. Can you tell me whats the color of these wires. And yes that is the webcam LED you are referring to
  • eagle338
    Surething. That will be all the info I need to provide a solution
  • eagle338
    eagle338 Mar 21, 2011
    Thats the motherboard serial number, Please get me the make and model of the laptop so that I can determine the model no of the same, I understood about the connector you are referring to but the problem here is not where the connector goes but where the wires go into the connector coz its broke right?
  • eagle338
    Ok. Its a Intel G40 express chipset. I have the port mapping document with me right now and all I need right now is a picture of the connector and we can finish this thing
  • eagle338
    eagle338 Mar 22, 2011
    Yes I have seen on the intel website a document regarding the pinouts and that is why I just need the colors of the wires to tell you which one goes where. The site also says that the 3 and 4 series chipset pot pinouts are same as Express 965 based chipsets. Anyways get me a picture of the broken connector and the wires. I will mark the pinouts for you
  • eagle338
    Do not use the reply button. Instead click on the Add Comment button in the upper right corner of the page. When the comment box opens it will have a pictures button just click on it , browse for the image and upload
  • eagle338
    Thanks for the pic. I am about to log off now and I will get you the piouts as soon as I log back in. Its beeen a really long day for me
  • eagle338
    So this is the one you are referring to. Look on the board for markings. The red wire is the + terminal of the LED and the - is the negative terminal of the same. If you can get me a high-res picture(So that I can read whats on the PCB) I can mark the leads for you because there are three black leads and I wouldn't want you to plug them in the wrong port
  • eagle338
    eagle338 Mar 23, 2011
    Yes I have a pinout here and it says the same thing, but I would like to be absolutely sure. If you can borrow a camera over the weekend or something and get me the picture, that would be great. This thread will remain open so you can take your time
    Master:
  • 344 Answers
I'm not so sure that is a webcam lead as you think. In http://ecx.images-amazon.com/images/I/51CJH8OoM%2BL._AA1024_.jpg is the cable you speak of there? 2 lead with connector? That would be the power supply for the screen back-light and the connector should only plug in a specific way.
Posted on Mar 19, 2011
  • Bryan Daugherty
    Bryan Daugherty Mar 19, 2011
    Oh my. Hm. I see your predicament a bit clearer now. There are things I would do but I couldn't even begin to tell you to do them. :( Risky, especially if it's not your machine you are fixing. My apologies.
  • Bryan Daugherty
    It's risky.. and I by no mean insist you do this.. but I would test the voltage on that lead... compare it with what I can visually see on the layout for what is Pos and Neg and put it in there as such. It IS possible to figure out what lead goes to what spot. Just takes effort. I'm sorry but that's about as helpful as I can get without being there to look at it
Dont know where ground wires go
Time to Perform: 10 to 15 minutes.
Preparation / Warnings:
If you have not already done so, please read the section on general installation and assembly tips. Pay particular attention to the notes about connecting cables.
For reference, you may want to read this section describing the cables and connectors coming from the power supply, and/or this section describing the connections on the motherboard.
Motherboards and system cases vary.
Your motherboard may not have all the items I mention here, and the same holds true for your case.
Furthermore, you may find that your case and motherboard don't match in every situation; for example, some cases have a turbo button and some do not, and some motherboards have a connection for a turbo button and some don't.
Watch out for "off by one" errors when attaching cables to pin headers. In particular, some motherboards combine several pin connectors into a larger block.
The individual connections are the same, the motherboard just physically groups the pins together into a larger matrix. Be careful when working with these as making a mistake is much easier to do. Refer to the manual.
If the system is in a tower case, it is much easier to perform this procedure with the case resting on its side.
LEDs have two wires and are unidirectional, so they will not work if attached backwards.
You need to connect the positive lead from the case to the positive pin on the motherboard, and the same with the negative.
Unfortunately, the case connector almost never has the positive and negative labeled. Fortunately, attaching them backwards will usually not cause any damage; the LED just won't work.
One tip you can use: most cases employ for each LED one colored wire (green, yellow, red, orange, blue) and another wire that is either black or white.
When this is the case, usually the colored wire is positive (signal) and the black or white wire is negative (ground). This isn't always true, but it's better than a random guess in most cases.
hope this helps
Aug 02, 2012 | Foxconn Winfast K8m890m2ma-rs2h Socket Am2...
Wiring motherboard to a atx tower
The motherboard manual will give you a breakdown of the cast-to-motherboard connections for the board. They differ slightly from board to board, but the connections are almost always found at the bottom front corner of the motherboard. There will be connections for the hard drive LED, the power LED, the power switch, the reset switch, and on some, the speaker (optional). The power switch and the reset switch connectors , 2-pin plugs, are not polarized, meaning that they can be connected to their pins either way without issue. The Power and HDD LED plugs are polarized, as LEDs have a positive and negative. Get this plug backward and the LED won't work. These are also 2-pin plugs. The power LED usually has a green and white wire (Green is +) and the HDD is usually red and white (Red is +) . Some motherboards have color-coded pins -- DO NOT TRUST THEM IF YOU DON'T HAVE A MANUAL -- they are not always standardized. Some motherboards have small print on the board adjacent to the pins to identify them. You CAN trust these. Otherwise, go to the Motherboard manufacturers site and get the manual for the board. The model number is on the board and can be searched for. If the manufacturer's name is not obvious, Google the model number and it will usually lead you to the manufacturer.
Dec 17, 2011 | Intel Motherboard
Power supply are working the fan of processor working there's power led but my system unit won't turn on.
hi friend...!!!!!!
there are some steps which you need to follow..
1) you need to clean your ram with blank white paper with soft hands..
2)you need to disconnect all your power connections which is attach with hard disk, cd drive, 24 or 20 pin connector on your motherboard every connection which is form S.M.P.S.. reconnect all connections.
3)reconnect your C.M.O.S battery which is on motherboard.
if you find this is helpful for you so please rate me this will encourage me to do more free work.
Sep 09, 2011 | Intel Motherboard
I need to know the correct placement for the power on leads to the motherboard on the emachine c2782 Thank you. policetac@yahoo.com
Use a magnifying glass to read the mobo print by the wire connectors. You should be able to spot something.
The on/off (power) button will go to the connector marked PWR or PW_SW or similar.
The LEDS will be (you should have 2 at least), one going to power led which should be named something like POWER, PWR_LED or PW_LED. And the other should be something like HD_LED or similar.
You might have to follow the wire from the case's front bezel if it's purpose isn't marked on it's connector, to figure which LED is hard drive and power.
You might have a reset switch on that case, and that would go to RES_SW or RESET or similar. LED's will not work if attached backwards. You need to connect the positive lead from the case to the positive pin on the motherboard, and the same with the negative. Unfortunately, the case connector almost never has the positive and negative labeled. The +/- is also hard to spot on the mobo. Fortunately, attaching them backwards will usually not cause any damage; the LED just won't work.
The LED will usually have the colored wires (blue, green, yellow, red, orange) as the positive, and a 2nd black or white wire which will be the negative. NOT always though. The reset switch has no polarity, so that won't matter which way it's connected. After you get it right, make a map of the pin connections and sock it away in case you need to remove/replace the mobo again in the future. I got a map of each of my computers, as they are all different (mobo's), though the cases are the same brand.
Jan 21, 2011 | E-Machines C2782 PC Desktop
I need to find out where the 3 little plugs go that are connected to the power button theres a blue/white black/white red/white plugs comming from it going to the motherboard
Sometime these connectors from the desktop case front panel have labels indentifing what each connector/plug is for. From your description they could be a reset switch or LED indicators for hard disk or power light etc.
If the plugs are not labeled then trace the wires back to the front panel to identify what they are attached to.
When you connect the LED indicators to the motherboard and it does not light up when they suppose to, then turn the plug around 180 degrees.
The LED are polarity sensitive ie they only light up if the + and - leads are connected to the motherboard correctly.
Nov 08, 2009 | Computers & Internet
SY-P4VTE attaching casing front panel to motherboard
Without knowing the manufacturer of the box, if you look on the connectors they will normally have things like SPKR, (speaker), POWER (on off button) HDLED (Hard disc LED light), TURBO. If they don't you'll need to trace the wires to where they go. The manual for the motherboard will explain which goes whrer once you've traced them. If not the motherboard will have (very small) writing againist the header on the motherboard.
Aug 21, 2009 | Soyo Computers & Internet
Mortherboard,keyboard replacement on gateway m360
First I would ensure my video cable was firmly connected. Sometimes that connector does not seat all the way causing what you are seeing. That is the rectangular connector leading fro the cable on left side of the LCD to the motherboard. Normally there are several hardware components related to a white display. LCD, video cable, or motherboard all causes of white screen. Have you checked external video? What was the original issue before motherboard and keyboard replacement?
Mar 14, 2009 | Gateway M360 Notebook
KM18G pro motherboard power connection, reset sw, power sw, etc.
Hi.
You can download the manual for your motherboard here.
Inside you will find information of where does each connector go. Each connector on the case has a marking on it (HDD, PWR, RST or similar) which stands for hard disk LED, power button, reset button and so on. Connect it to the right place, and problem is solved.
If you need any further assistance, feel free to ask.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 18, 2009 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
LG PHILIPS LP156WH1(TL)(A3) COMPATIBLE LAPTOP LCD SCREEN 156 WXGA HD GLOSSY CCFL (654367710340) Logo
280 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
