We lost one leg of our power last night for about 3 hours, I unplugged everything but our 4 year old coleman furnace. Now I have 120v to it, but nothing works, and I cannot see a code light. Is it on the mother board? What else can I look for? Thanks.
  • A Miller Mar 19, 2011
    Is this in a camper? Are you certain you are getting 110 volts on both sides of your 50 amp (to both neutral and ground?)? Check with a volt ohm meter to be certain. Have you double checked all the breakers in your power panel?
  • Josh Marxen Mar 19, 2011
    It's in a house. Its a York furnace with a coleman badge. I ran the check in the furnace itself and had 110v from hot to neutral where it splices in from the fuse and switch down to the motherboard. I changed the batteries in the thermostat. The inside of the door has a troublecode list but I have no lights at all.
  • 8,404 Answers
If you are in the USA, this is very unusual that you would lose one/half of your power since it comes from the same transformer. Still, you say you have lost 1/2, I have to accept this ... When this condition exists, I would expect that one-half of your main panel is now (was) dead and all 220 volt circuits would not work (since they receive only one leg).
Your York furnace, you do not say if it is gas (electronic or thermocouple) or electric ... I am not familiar with this model. If it is electric, I would expect it runs on more than 220 depending on its capacity. Still, the control panel probably runs on no more than 120 and perhaps 12 or 24 volts. I would be looking for a fuse on the control panel. If you have a volt meter, insure the panel is receiving either AC or DC power. Replace the fuse if required. If there is power there to the control ... but nothing happening in the furnace, there could be a fault on the board. You did say the thermostat is functioning properly.
Some models require a 5 or so minute delay in starting or changing modes or temps ... please keep this in mind though I am certainly not implying this is the the case with your unit.
This is what I have to say ... I am not a heater specialist, though there are experts here who are. If you desire, you can contact any of the experts on line (there is a cost associated with this - message or chat). Simply click on the link that mentions chat with a specialist ... or the link to find a York Heater expert.
When you evaluate this answer, please keep in mind I have tried to help you and suggested to you a course of action to follow beyond my expertise.
Thank you for your interest n FixYa.com and I hope you get your machine going easily, simply and economically.
Thanks.
Posted on Mar 19, 2011
Testimonial: "Thanks!"
4322 coleman furnace
Check electrical xxxxxxxxxxxxxxxxxxxxxx
May 23, 2014 | Coleman Heating & Cooling
I have a coleman powermate maxa 5000 er Generator. Model # PM0525202. The powercord plug came loose and burnt the plug and the receptical(240). I replaced the plug and receptical and I am not getting...
If this is the model I am thinking of, there are 3 outlets. One 240V (L1, L2, Neutral and Earth ground. Some models use a 3 terminal receptacle that combines Neutral and earth.), one 120V receptacle (L1, Neut, earth) and another 120V receptacle (L2, Neut, earth).
If you verified fuse and circuit breakers are good, turn on the generator and verify you get 120V on each of the two outlets. Measuring between the narrow blades of the two 120V outlets should be 240V.
***Shut off the generator.
With a test light or ohmmeter, check continuity from the earth terminal of 120V outlets to 240V outlet. Likewise for neutral (wider blade on 120V outlet). Lastly, check continuity from Narrow blade of each outlet to the 240V outlet.
I suspect that you miswired neutral and earth. On a 4 wire PLUG, it is customary to connect earth and neutral.
Work safely so you can give feedback.
Aug 30, 2017 | Coleman Electrical Supplies
Coleman kersene furnace in mbile home, (furnace is only 4 years old--just inspected 3 months ago) However,it ran fine last night, now it will not come on unless you hit the ret switch, then it tuns 20-30...
Sounds like a fuel or ignition problem. If the unit does ignite when its reset it could be a bad Cad eye or primary control. If it does not light off when reset,DO NOT re-rest anymore and call the Heating contractor back to inspect and repair.
Dec 12, 2009 | Humidifiers
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Furnace not cycling properly.
you might want to check the filter, if the filter is restricting the airflow the furnace will over heat and it will shut down. if you turn it off and on it will reset it and it will try again. Pull the filter out half way and try that, if it runs fine then clean the filter or get a less restrictive one.
Feb 06, 2009 | Coleman Propane Forced Air Heater...
I have a Honeywell H220a humidistat and have everything hooked up, but I cannot get the wiring to work. The wiring diagrams do not include the selanoid that comes with the humidistat. Any suggestions. The...
Thanks for your question Mike,
The wiring for your humidistat and solenoid are fairly simple, you will need 24volt t-stat wire, you have the two wires at the Solenoid, one wire goes to the terminal board at the furnace, it connects to the (c) or common terminal, the other wire connects to one leg of the humidistat, run another wire from the other leg of the humidistat, to either the HUM terminal on your furnace circuit board, make sure its not a 120v leg, should say in the owners manual, if if is or your not sure, connect that same leg to the (w) terminal at the furnace, this way it only comes on in heating mode, some models need a second 120v-24v transformer, but you would still wire it through the same way, only exception is that you have to hook up 120v to the transformer, and route your wiring like I told you above but through the transformer to complete the circuit, hope that helped you out Mike, please let us know, thanks again, mr.grzz
Jan 10, 2009 | Honeywell HE220A1019 Whole House...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Intertherm ultraflex mobile home furnace
Is this a 120v motor, or 220v? If you checked for power, I assume you kind of know your way around a meter. When checking for power, don't check to ground, check the line. You could have power going in, but unless its going back out, completing the circuit, or missing a leg, in 220v case, it still will not work. Also, most heaters have some sort of delay, so after you hook it back up, and the burner heats up wait a few minutes for the fan to come on.
Dec 30, 2007 | Heating & Cooling
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
