Question about Kenmore 15769 Built-in Dishwasher
Built in dishwasher. Dishes are clean but leaves the interior dirty. Have cleaned it with dishwasher cleaner, then a few weeks later its grubby again.. This has just been happening in the last few months.. Any suggestions?
  • Kenmore Master
  • 3,361 Answers
Check your drain hose to make sure no water from the sink is draining back into the dishwasher.
If it is,re-hook the drain hose up high under the sink.
Next.
Start the dishwasher without dishes or detergent.
Once the fill and was cycle begins,open the door and por in 1 quart of WHITE vinegar and resume the wash cycle to completion.
Posted on Mar 19, 2011
Clogged Bosch SHU 9920 dishwasher
-Sounds like the pump is not working properly or the drain line you connect to sink directly instead to the breath cap before to the sink. Or the breath cap locate too low.
-Make sure the breath cap is mount higher than the line to the sink. (Or as high as possible) This is to prevent any water from the sink pour into the dishwasher.
Good luck
Mai
Jun 16, 2017 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Filter doesn't self-clean
hello diane,
i would think that unless your model says it is self cleaning then yes it is normal to have to clean the filters on a dish washer. the amount of time between cleans would depend on how dirty your dishes are.
Apr 20, 2013 | Kenmore 24 in. 15932 Built-in Dishwasher
Glasses are cloudy and cutlery and dishes are not clean. using cascade with dawn powder. dishwasher is brand new, installed one week ago
Sorry to hear your having problems with your new dishwasher. Please review your owners manual for great tips for the best results on cleaning your dishes. Here are a few steps to take to get your dishwasher working:
  1. Run you sink water for 3 min on hot before you start your dishwasher. This allows warm water to enter the dishwasher and helps aid in sanitizing and cycle time. Remember water entering must be at 125 degrees.
  2. If your using power detergent be sure to use rise aid. All new dishwashers require this additive for best results.
  3. If you have hard water your going to need a dishwasher cleaner and use it once a month. I recommend dishwasher magic. Kills 99.9% bacteria and leave a great scent. I use it myself.
Dec 09, 2010 | GE Profile PDW8400J Built-in Dishwasher
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Our Kenmore dishwasher leaves a fishy odor on dishes
Go to Walmart gets some DISHWASHER CLEANER....works great...also clean out both screans and the water arms have holes...clean them out with a tweezers.
Sep 20, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore dishwasher is not washing properly and leaving dirty water in the bottom when it is finished, Can i fix it?
yes you can, what you want to do is right after you read my solution... rate it. :D but anyways wht you have to do is take out the filter underneath the bottom tray where the dishes go. and clean out all that yummy wet gross food from last week. it'll be all gunked up. that's stopping the dirty water from draining.
Jun 02, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
For the last week none of my dishes are getting clean. The diswhasher seems to be working fine, just fogged, dirty looking dishes? HELP!
You can visit me for more advice but I'd say to make the filter inside the dishwasher is cleaned out if your dishwasher has a filter.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Jan 29, 2009 | Kenmore 15899 Built-in Dishwasher
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
Just not cleaning
run a cycle thru with no dishes and 2 cups of vingar this will flush out the unit then run a normal load should be ok let me know THERE also is a product called dishwasher magic you can run that thru as well but the vingar is cheaper
Mar 15, 2008 | Maytag 24 in. MDBH955AW Built-in...
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore 15769 Built-in Dishwasher Logo
144 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
