Question about Tricity Bendix AW1000W Front Load Washer
My machine fills with water even when it is not plugged in
  • 57 Answers
The machine relies on water pressure to close the valve when not in use. In low pressure areas, this doesn't happen. Change the valve and take out the high pressure limiter (in the valve itself, looks like a small thimble of mesh)
Posted on Mar 23, 2011
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
Why is my GE top load mechanical washer not filling with water?
You may need to use a Y adapter to feed pressure to both inlets to get the machine to fill. If it senses no pressure on one inlet it wont fill. You can run both inlets to on source. Since you did not post the model number it is hard to say. Some machines also test the water temp to see if it is warm enough to start or it needs to preheat.
Mar 05, 2018 | Washing Machines
Washer fills all the time even with the plug disconected from the wall. You have to turn the water off. The model# is wsxh208v1ww
You need to either clean out the water valve or better yet replace it. The water valve is the part where the fills hoses connect to the machine. Hope this helps.
May 24, 2011 | GE WSXH208A Front Load Washer
My washing machine is a hotpoint WF240. It started to overflow with water and spilling onto floor. We pulled it out from wall and found outgoing pump had fallen down, we put it back where it was supposed...
The machine will fill with it connected to the Electrical supply then stop if unplugged providing the fill valves/ water is okay....If it keeps on filling after unpluged then sounds like faulty fill valve,if on the other hand it fills without stopping when plugged in then its your air hose or Pressure switch at fault,Good luck
Apr 06, 2011 | Washing Machines
Bunn vpr steams everything out fill hole and nothing comes through copper tube, even after cleaning tube and head.
Fill water tank until water comes out from sprayhead, THEN plug it in it should be OK.
IF the machine keeps blowing steam/keeps boiling the water, The thermostat is defective and must be replaced.
NOTE: If you don't use the machine for a couple days, UNPLUG IT. The water will evaporate if you don't unplug it.
Jan 13, 2011 | Bunn VPR Coffee Maker
The dryer starts fine but the motor doesnt even start when i try to use the washer.
If it fills with water it could be the fill switch, not sending a signal to the timer. If the timer isn't moving it could be the timer which sounds the most likely, I would need more information but these are great machines. If it is not filling with water check for water at valves or hoses and check for the power cord plug making sure it is still plugged in correctly.
Nov 07, 2010 | Whirlpool LTE6234D Top Load Stacked...
Washing machine does not stop filling
check hose to water level switch off or plugged or bad switch. unless fills even when cord is unpluged then bad water valve
Dec 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Water fills washer even when it is unplugged
Replace fill valve. It is located where the water hooks up to washer. Easy to change. The valve gets plugged with sediment and needs to be replaced.
Jul 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Nespresso D300 says "Fill Water" even after I have filled container.
Even if you fill the tank with water, the machine will display this message when it is empty inside (the pipes, heating element, etc.) You need to prime it: run some water through it by running the steamer/hot water wand.  That should take care of it.
Jul 23, 2006 | Nespresso D300 Espresso Machine
Tricity Bendix AW1000W Front Load Washer Logo
125 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
