Question about Whirlpool Refrigerators
I have a whirlpool gold gd5shaxlt02 icemaker has stopped working and the control light is flashing red what should i do?
SOURCE: icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Posted on Apr 27, 2008
ghappliances
  • 126 Answers
SOURCE: Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
sdmc73
  • 121 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
the module on the icemaker may be bad or the emitter-recever
Posted on Nov 29, 2008
aasc
  • 1606 Answers
SOURCE: ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Posted on Sep 05, 2009
aasc
  • 1606 Answers
SOURCE: Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Posted on Sep 27, 2009
Testimonial: "Will try suggestions. Thanks!"
How do I reset a flashing green start button
Blinking start button usually means a bad door switch cannot reset the control does not see the door as closed
Aug 14, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
Model # whirlpool gd5shaxlt02 \r\nhow do I remove
take pin and place in between the body and gasket and peel off
Jun 06, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker will not make ice
If you have water sitting in the trays and no action is happening, then i suggest replacing the ice maker complete as these spares are pricey and take a while to get to you , (In the hope that they are correct). On some units there is a small test button. If you have one, push or switch it to activate icemaker. Often this resetting brings the ice maker back on line.
May 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Red light flashing on ice control panel in freezer section of my Whirlpool gold GS6NHAXVT02. I have the setting on ''on''.
The red light is supposed to flash. The number and frequency of flashes is a diagnostic tool we use to determine what is wrong if the icemaker is not working. If your icemaker is not working, count how many flashes before it rests, and let us know. Good Luck, Appliance Specialists
Jan 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
In the door ice maker has stopped working. the light controller s
when you look at this icemaker there are 2 sets of strippers 1 stationary the other moves. teh one that moves is normally at 2 o'clock position facing the front cover of icemaker. if these teeth are in anyother position for longer than 10-20 minutes then you most likely have a bad motor module on the icemaker, this is a very easy repair you will need partnumber 8201515 from whirlpool or local appliance supply house. thx peyton
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
