Question about Krups Coffee Makers & Espresso Machines
I have problem with Keurig Milk Frother Model LM-150P when I'm trying to turn it on by pushing the button is just shuttin down.The power is definitely coming to the unit and i can see the grin button when i push the button but right away i hear also a click and the unit is not working .
I had the same exact problem and called Keurig this morning at 866-901-2739 and they are sending me a new one for free with no questions asked. Now that is what I call customer service.
Posted on Oct 30, 2013
  • Frank Cantelmo
    Frank Cantelmo Nov 20, 2014
    Same problem, I called Keurig @ 866-901-2739, spoke with CS and they are sending a replacement, no charge. Two thumbs up.
  • 833 Answers
SOURCE: Steamer and milk frother not working
This sounds like one of several problems:
1. Does any indicator light come on? If there is one and it doesn't you either have a bad thermostat (size of a dime/1/4 inch thick) black item with two wires attached to the chamber or a bad heater. Check both with an ohm meter...Resistance of any kind across the terminals means okay.
2. Could be the switch. Same kind of test.
3. If you've got a steam leak, deal with that...new cap or valve.
Make sure all wire fasters are clean and bright. If screwed down, make sure they are tight. Cycle each connector off and on to clean them.
Remember: always work on your unit with it unplugged. You may need torx screwdrivers to open this unit. Any hardware store will have sets of these items.
Posted on Jun 16, 2008
SOURCE: THE NESPRESSO MILK FROTHER HAS STOPPED FROTHING
I contacted Nespresso who may well replace the item
Posted on Nov 27, 2009
  • 21 Answers
SOURCE: My Nespresso milk frother did not come with
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Posted on May 08, 2010
SOURCE: Lost my Nespresso Aeroccino Milk Frother Hot Milk Whisk
Call Nespresso customer service at 800-562-1465. Replacement set of 2 wisks were $2.95 + shipping
Posted on Jul 01, 2010
  • 155 Answers
SOURCE: The milk in the frother
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
Posted on Sep 14, 2010
My Keurig Milk Frother stopped working. The green light comes on but turns off immediately. Is there something I can fix?
How long have you been using that? Why not try the frother from Kitchen Ace. I can assure you that the quality of there products are really awesome!
Amazon com Kitchen Ace Can Opener Stainless Steel with Smooth Edge...
Sep 12, 2014 | Coffee Makers & Espresso Machines
Doesn't turn on
Intrinsic failure needs repair.
Nov 07, 2013 | Keurig Caf One-Touch Milk Frother
Keurig milk frother got wet now not turning on
It is burned out and won't heat. RePlace.
Nov 21, 2012 | Keurig Milk Frother
Why is my nespresso Citizmilk D120 milk frother not spinning? Milk does froth up.
I have the same problem. it was working beautifully but then stopped for no reason to turn. If I hold the whiskers sometimes they turn and other times not. Weird! it happened some months ago and then I tried a couple of months ago and it suddenly worked. Now the same problem has re-occured. Wonder which part needs to be replaced - does anyone know?
Mar 03, 2012 | Nespresso Citizmilk D120
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
The milk frother is making the milk spit out of the jug and not producing any froth it used to be fantastic.
Check the end of the frother,ensure the center is protruding.
If not remove the lower end of the frother and push the center towards the end and click it into place.
This is a very common problem.
Oct 21, 2009 | Gaggia Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
1,584 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
