Refrigerators Logo
Posted on Mar 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE "frige model GTS18XCSFRBB; has
Anonymous
Level 3:
  • Refrigerators Master 3,361 Answers
  • Posted on Mar 19, 2011
Anonymous
Level 3:
Answers
3361
Questions
Helped
1029167
Points
10654
Loosen the screws on the top bracket on top of the refrigerator.
Not the hinge between the doors.
Pull up on the door handle and tighten the top bracket screws.
I have a GE side by side refrigerator (Model #GSL25JFXLB and the doors will not close all the way
Leveling the refrigerator so that the doors close easily is one of the most important ways of getting the doors to work properly. Here is a link to a Profile/Artica Service Manual Go to page 24 through 26 where the manual explains what you need to do to get the doors to open and close properly. If you have questions I will be here to answer any questions you may have, Thank You Sea Breeze
Doors won't close independantly. Magnetic "strips " hit and freezer or frige stays open slightly
Has the unit recently been moved or the doors removed at any time? Either the door are not aligned or they are damaged around the hinges some how. I would adjust doors from the top of the unit, assure not product (food) could obstruct the door from closing. Lastly double check closer at the bottom, this is a two piece system and I had seen this come apart recently.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
1helpful
STARTED, ROTATED A FEW TIMES, FILLED UP WITH WATER, NEXT MODE "WASH" BEEP BEEP. BEEP BEEP.. "d E" .. MACHINE STOP. POWER STILL ON. CONTROL BUTTONS STILL FUNCTIONING. IT IS A LG...
he error code "dE" signifies a door open error. This may simply be because the door is not all the way closed, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
"door error", "start?" - When
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
We have a relatively new (about 6 weeks old) GE OTR microwave--model is JVM1540SP1SS. Yesterday it started "running' even when there isn't any food in there and before we push any buttons. When the...
It sounds like a sticky door switch. There are several switches operated by the door latches to keep the oven from operating with the door open. It's possible someone got a little too rough when closing the door, which can cause misadjustment.
Since the oven is so new it will still be under warranty, though. Why not let GE fix it? You just need to tell them it's not working properly. First call the retailer where you purchased the oven. If they arranged installation they probably also handle service. Otherwise you can contact GE's customer service as instructed in your owner's manual to find out how to handle the repair.
1helpful
Amana, top single door drags when closing
I will tell you how I fixed this problem for a one time payment of $19.95. Or, go to appliancerepair.com and get the answer for free. There! That'l FIXYA.
My refrigerator does not cool properly sometimes no ice technician advise multiple leaks in the condensor coil but this problem has continued from the frige was brand new
leaks in the coll ( condenser coil would cause the frig to quit cooling completly.. look for slow fan and dirty cond. ( clean 2 to 3 times a year .. ) make shure your door's close properly and seal .. use a $5.00 bill close it in the door at different points if it is loose or falls out . ( door seals are problem .. )
3helpful
2answers
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
