Question about Welding Tools
I just need to know what my sp250 idlearc lincoln mig welder is single phase or three phase, my gurage has three phase running in how do i wire in ,if single phase
  • 407 Answers
Hi:
Your Machine is single phase, and it could be a 208/230V or a 230/460/575V depending on the model. Check what kind of voltage do you have at your garage first, before attempting to do the following:
On a three phase wiring you will have 4 wires with the following colors; green, red, white and black. If you have 208/220/230 volts available at your garage you can connect the green, white and black wires, always green being the ground cable in the middle, black and white don't matter which side you screw them in.
Before attempting to connect a 480V to the machine check machine's plaque information in the front (or back) for real voltage, because this voltage can burn the PC board of you machine. The same color sequence applies to the 480V.
Good luck.
If this was useful to you, please vote.
Posted on Mar 21, 2011
Wire schematic
If the welder is single phase 110v use a dedicated 20A standard household circuit. If 220v single phase use a 50A RV or weld receptacle connected to a 50A dual breaker with common trip. Make sure the breaker is the same brand as your panel. If the welder is 3-phase connect the wires B-O-Y (Brown Orange Yellow) at the breaker (3 phase 50A) and see if a color code match can be applied at the welder, although the only issue is whether the wire feed will run forward or reversed. If the wire feed is reversed then move any two wires of the B-O-Y set to change the rotation.
Aug 25, 2014 | Welding Tools
Electrical wiring
The CP-300 and CP-200 were never designed to run on single phase. You can buy a 3-phase generator (see military surplus) or a phase converter. You will need a pretty big one - like one rated for 20hp to use the full potential of the welder. That is also pretty expensive - say $1000. However, if you have a shop, you can buy used 3-phase equipment sometimes significantly cheaper than 2-phase stuff. So you buy that expensive converter and save money on all the other equipment you will buy. Or sell it. Or scrap it - some older welders had big copper wound transformers - a few hundred bucks worth of copper.... some had aluminum though... Good luck.
Jul 08, 2013 | Miller matic 140 Mig Welding Package W/As...
Wiring a welder 480v to 220
I ahve a linclon ideal arc 250 welder which is 480V 3 phase I would like to change it over to 220V single, what are the procedures.
Mar 03, 2013 | Miller Welding Tools
Three phase power went through our single phase butters mig. no fan or torch now
Hi:
Sorry to say this but feeding 3 phase current to a single phase machine will fry the PC board.
You will need to send the machine to your nearest welding/maintenace shop.
May 19, 2011 | Welding Tools
I have a WESTINGHOUSE WELDER type rs 250 that is wired for 440 volt and need to change to 220 volt.
HI:) If that is a 3 phase 440 volt and you want it to use 220 volt 1 Phase you will have to get a phase inverter to change it from a 3 phase to a single phase.
Dec 19, 2010 | Welding Tools
How do you hook a miller s-22p8 wire feeder to a lincoln ranger 10,000 plus engine driven welder?
you can't, the S-22P8 it's not a volt sensing wire feeder, it requires 24V or 115 with an adapter. FOr CV machines only.
Dec 08, 2010 | Miller Electric Mfg Co 903376 Deltaweld...
Wiring a single phase outlet
test wires, white u need supposed to be ground, and usually two of the other wires is hot mostlikely red green attach only 2 hot wires if 3rd is hot cap it, home depot also sells basic wiring book that will guide you through this issue
Jul 07, 2009 | Welding Tools
Lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Jan 18, 2009 | Welding Tools
Welding Tools Logo
127 people viewed this question
Top Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Welding Tool Expert? Answer questions, earn points and help others
