Question about Samsung Jet S8000 Cell Phone
How do i connect to ip adress on my phone so i can use a router
    Sergeant:
  • 162 Answers
You would need to setup your wireless connection through your phone and connect to your wireless network. Than you can see your phone on your network.
Posted on Mar 19, 2011
I P ADRESS FOR MIVAR TV
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit IP-details.com and get the IP.
Mar 01, 2014 | ip-adress.com
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
Can't get access limits to work
there is no internet connectivity
check your router ip adress
check the computer ip adress is same range of router ip
if not,, please assign same range of router ip manually
please letme know this helpful
Jan 07, 2011 | Linksys WRT54G-TM Wireless Router
Can i have lan drivers please web adderes
There is no need for drivers for your router, just connect with your browser at the router's ip adress. In case you don't know this adress do the following.
Connect your computer with ethernet cable at the router and after the connection has been established, hit start - run - type cmd. At the new black window type ipconfig and hit enter. You will get the results for the ethernet connection. The ip that reffers to the "default gateway" is the ip adress for your router.
In case of a problem or clarification, or need further details, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Oct 23, 2010 | Computers & Internet
I recieve error that I can't get a Ip adress. WEP security password goes to the router but no Ip adress is making it back . I've tried loading a static IP adress, using another unsecured network. resetting...
Try using the HEX password instead of the ascii passphrase - also try to reset your AP temporarily in order to test the connection without ANY wireless security - if that doesn't connect, then the problem probably lies in the wireless router itself.
Oct 20, 2009 | Microsoft Xbox 360 Elite Console
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
Cannot connect to sky router
sometime this would because your router is thinking that your phone is a hacking device and so it will not allow full connection so if you put a password on you router it would probily fix your problem
Jan 21, 2009 | Belkin Wi-Fi Phone for Skype - Wireless...
My xbox 360 says i need an IP adress
The XBOX is configured for connecting to a router or server that will assign it an IP address. Connect it to your router instead of your laptop.
Jan 06, 2009 | Microsoft Xbox 360 Console
DWL-G710 - Not able to logon with standard IP-adress 192.168.0.30
Must have same IP-adress on Router and Repeater 192.168.0.x. Then have cable from router to PC and from router to repeater. Then logon to repeater and the Dlink-repeater SW have a command where you can see available networks. See to that you choose the right one and that channel, name and password is the same as the router. The repeater will not be visible when you search for available networks because it has the same name as the router. I also had to restart the router and the repeater before it worked.
The repeater gives us excellent connection where we otherwise has no connection, so I can recommend it.
Aug 27, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Samsung Jet S8000  Cell Phone Logo
37 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
