Is there a driver for Rollei Diafilm Scanner DFS 120 SE ?
  • 8,404 Answers
You have not mentioned the Operating System you expect to use with this device, a critical bit of information in properly responding to your question.
If you are running Windows 7, please check this listing for your device: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
There are similar listings for XP, Vista, 2000 etc.
Alternatively, you can check the manufacturers web site if you are not using a MS operating system.
Thank you for your interest in FixYa.com
Posted on Mar 19, 2011
Driver for Rollei cardvr-70
Online from the manufacturer.
Jan 12, 2015 | Rollei Cameras
I cannot retract the lens back to my Rollei 35 se
Your question seems to be mis-categorized under slide projectors, if you are asking about Rollei 35 SE camera, the lens will only retract if you cock the shutter with the wind lever, then press the button next to the shutter release and rotate the lens a few degrees.
Nov 13, 2013 | Rollei 66 Dual Slide Projector
My dad is trying to convert slides to digital format using a Rollei DF-S 110 SE scanner. His Mac does not recognize the scanner and there does not appear to be a photoimpression 6 version for Mac. Any...
There's nothing you can do to make that scanner work for a Mac because it was made (and its software) exclusively for Windows.
You could try:
-use the scanner and its software on a Windows computer -go to a computer shop and have the slides scanned and saved on your flash drive
Mar 20, 2011 | Arcsoft PhotoImpression® 6 Full Version...
Hallo.I bought the DiaFilm-Scanner "Rollei DF-S 120 SE " .Its Software/Driver is "PhotoImpression 6".I also tried Gold 6.5 from the Internet - but it does not work completely - The PC does not find the...
Install the driver for your camera from the manufacturers website.
Once the camera is installed the software will probably find it.
Also check with Arcsoft and make sure your software is compatible with windows 7. It may require and additional driver.
Oct 03, 2010 | Arcsoft PhotoImpression® 6 Full Version...
Hello fellas! I have Rollei digital camera, and when i plug in USB on computer it says Driver wasnt found, it worked on my old PC, help me guys please! Rollei is very good camera and i can't upload...
It sounds like you just need to go to the support site for Rollei and download the compatable driver/software for your new computers operating system.
Here is a link for the new Rollei website. I didn;t see the drivers listed but that usually means you can contact them and they should let you know where to get them. The email below that is for support.
http://www.rcp-technik.com/typo3/index.php?id=rollei_de_home&L=1
service@rollei.com
I'm not sure if you can use any other drivers but they should be able to tell you.
Aug 11, 2010 | Rollei dr5100 Digital Camera
I need a driver software for my Mustek flatbed scanner with model no: SE A3 USB 600 PRO.
http://mustek.com/mustek/supportdrivers.php?&show=drivers&disp_cat=Scanner&disp_sr=USB%20Port&disp_mod=600%20USB&disp_catid=18&disp_srid=31&disp_modid=120
Jul 31, 2010 | Mustek A3 USB Flatbed Scanner
Pioneer DEH-P4000 DFS Alarm driving me crazy
How to disarm DFS alarm How to disarm DFS alarm Disarming alarm Upon entering your vehicle and within the ENTRY DELAY TIME set within the DFS alarm Menu, attach your Pioneer Detachable face. If you have forgotten the Detachable Face Panel: If the STARTER DISABLE is ON, insert the ignition key in the ignition within the ENTRY DELAY TIME, then turn the key from OFF to ON 5 times within 1 minute. If the starter disable is OFF, insert the ignition key in the ignition and turn the key from OFF to ON within the ENTRY DELAY TIME. CAUTION: If the starter motor will not run, the cause may be the DFS alarm. To check whether the DFS alarm is cause, try switching the position of the switch installed according to the AVOIDING TROUBLE section of the installation manual. If the DFS alarm is the cause of the trouble, then the starter motor will run. In case, confirm DFS alarm operation in safe place. If there is no problem, switch back to its original position. If left at the newly switched position, some functions of the DFS alarm will not operate. If the starter motor will not run after switching the switch, something other than the DFS alarm may be causing the problem. Have the vehicle checked at a nearby dealer. ----------------------------------------------- Select the DFS alarm feature ON/OFF mode (alarm ) in the initial setting menu. Press the arrow (up) button to switch the DFS alarm feature ON. Press the arrow (down) button to deactivate the DFS alarm feature. Press FUNCTION button for 2 seconds to enter the DFS alarm setting menu These are a couple of things I found to fix this problem. Here is the link that I got them from: http://www.pioneerelectronics.com/pna/v3/pg/support/knowledgebase/0,,2076_310069579,00.html Hope this helps:) Jason
Sep 04, 2007 | Car Audio & Video
Computers & Internet Logo
317 people viewed this question
David Payne
David Payne
