Question about Canon iP100 Portable Printer
Why am I getting a streak across the paper where the ink is not printed?
    Sergeant:
    Champion:
  • 236 Answers
Your printer may have spilled toner
Posted on Mar 19, 2011
My hp officejet pro l7680 all-in-one printer started printing with black streaking lines. I switched paper today from 20 lb to 24 lb. Would that make a difference?
No that should not make a diffrence!
Try the Following Steps:
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Sep 27, 2011 | Office Equipment & Supplies
Prints in streaks, prints about a 16th to an 8th of an inch ring them skips one, clear across the disk
Sounds like a printer problem...take the ink cartridge out and take a paper towel and moisten it with some water and wipe the cartridge off on the paper towel and then put it back.
Oct 29, 2010 | HP Pavilion AMD Athlon II X4 630 QuadCore...
My printer streaks ink across the paper when i print
just replace toner cartridge. I think the cartridge drum is broken
May 21, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
My printer is leaving horizontal streaks across
When I had the same problem, I found out, that Epson did not like Generic Ink. As soon as I replaced it with Genuine Epson Ink, it was fine.
Make sure you do Maintenance, Nozzle Check and Head Cleaning. You might be clogged?
Good Luck.
Nov 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Streaks in printing with my HP officejet L7680
It could be paper dust on the paper. Try putting some new paper in the printer to see if that fix it.
Aug 13, 2009 | HP Hewlett Packard Officejet Pro L7680...
I'm getting a streak of ink down the paper
change a toner.
when you have the toner out. clean the heater element (glass). make sure the printer is off and the heater element is cool before you do this.
May 14, 2009 | Dell 3100cn Laser Printer
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Left & right streaks when printing
Hi, it sounds that your printer may require service to clean the printhead thourouly.
Tirzo
May 09, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Streaks down middle of and rainbow colors on top of printed pictures
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
or you can use a hot water to clean surface of your catridge
Mar 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon iP100 Portable Printer  Logo
62 people viewed this question
old marine
old marine
