Question about Brother MFC-7820N Printer
SCREEN MESSAGE -- REAR DOOR IS OPEN WHEN IT IS CLOSED. NEED TO KNOW ABOUT SENSER FOR DOOR.
    Sergeant:
    Champion:
  • 236 Answers
Try resetting to factory defaults
Posted on Mar 19, 2011
I have a becCo senser dryer I paused the button today and it won't come back on any suggestions what I can do
Did you try opening and close door some will not start till door was open and closed once Or unplug wait 2 min plug back in should reset if not board interface or control board stuck button
model # AGE ? needed to get better details
Apr 25, 2015 | Dryers
Garage door senser not working
What doesn't the sensor do with an obstacle?
Feb 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
HP 3050 door open message
Your printer HP 3050 has problem of door open the printer had 3 or 5 senser in which one senser is not working so the message comes on screen
Jan 01, 2011 | HP LaserJet 3050 All-In-One Printer
We keep getting a message -paper jam check open rear door. checked, no paper jam, opening and closing rear door will allow the print job to go through. It will work for a few print jobs, then the same...
It's probably a sensor on the fuser. There are 2 and sometimes they get stuck and just closing the rear door hard will release it. Replace the fuser.
Dec 08, 2009 | Dell W5300N Laser Printer
Changed ink cartridge; can't eliminate"door open" alert
Hello sir; On the door hing, it conect with door senser when the door open or close going to actuact the door senser, so check the door senser is moving free.
Aug 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Door will not close unless you hold hard wired button in till clo
You can jump the sensors out to test them. Just attach a wire between the two opposite points and then test to see if that's your problem.
Jul 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Error message-Close the back cover
It appears that you have a broken back door have a look on the door to see if there is a broken piece of plastic as when you shut the rear door a tab pushes against a push switch letting the machine know that the door is closed. if you cannot see a broken piece then the switch it faulty try this by push a flat screw driver on the switch and check if the message disappears.
Thanks J
Jan 07, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
Brother MFC-7820N Printer Logo
78 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
