Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Blades won't engage. Nothing lose or out of place
  • Craftsman Master
  • 8,404 Answers
Is this an electric or mechanical clutch. If electric, check the power to the clutch when the switch is "ON" Be mindful of the operator presence switch. There will be no power on the line if there is no one on the seat. So, with the engine not running but the ignition switch in the run position, and the clutch switch on the on position, check the power to the clutch with a volt ohm meter while someone sits upon the seat.
Mechanical clutch. Double check the belt is properly routed.
Double check the blades ARE free to rotate in either event.
Posted on Mar 19, 2011
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
Troy Bilt Kohler 18hp riding mower won't start.
there is a main fuse . usually hidden in the wiring . contact a dealer for assistance
Oct 07, 2017 | Troy Garden
I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Gary
Sep 11, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
