Question about Kenmore Refrigerators
I have a series 55251/55271/56261 Kenmore Refrigerator and it will not dump the ice. It makes it, but won't dump it.
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 3 Answers
SOURCE: fridge won't make ice
There is an optics test procedure you can perform on your own to confirm what the repairman says. Assuming you have a whirlpool-made Kenmore (if you have a Pur water filter at the bttom left of your unit, you do), see here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Basically, the icemaker won't initiate a harvest (dump) cycle unless the electric eye through that cutout at the top of your icemaker can see across the top of the dispenser. If the lens is dirty, or if either the emitter or receiver boards are bad, the optics won't connect. There's a simple diagnosis procedure in that pdf above. Since your fridge is from 2005 like mine, refer to the "post 2002 redesign" optics procedure. Basically the test is to open the fridge and look at the LED, then to close the flapper on the left wall of the freezer and see the change in LED behavior. This can confirm or deny an optics issue. Also, if you remove the little plastic grille at the bottom of your fridge, there'll be a piece of paper folded and stuffed in there with the diagnostic procedure in it as well. To do the full diagnostic procedure, you'll need to remove the icemaker and install a jumper, but to debug optics only, all you need to do is open the door, close the flapper, or maybe push in the door switch and look at how the LED responds.
Posted on Mar 18, 2009
rylee_smith
  • 8619 Answers
SOURCE: ice maker stopped
Hi!
Please check these:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 23, 2009
Kenmore model 10659282990 side by side
could be a piece of ice wedged in there
Oct 24, 2013 | Refrigerators
Kenmore refrigerator side by side ice maker not making ice.no water going to the ice maker??.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 09, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker not working
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 17, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker stopped making ice
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Kenmore side by side refrigerator wont make or dump ice in holding container
Ice maker will not make ice. just acts like it is frozen up or something like that
Oct 24, 2008 | Kenmore 44103 Side by Side Refrigerator
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
KENMORE REFRIGERATOR
Need a model # ... mostly likey better to just replace ice maker if that old.. 12-15 if same age as ref.
Sep 06, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
282 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
