Question about Sony Televison & Video
How to change a projection blub - Sony Televison & Video
    Top Expert:
  • Sony Master
  • 75,462 Answers
Hello
To chage the bulb in a projection tV do the following
1. Turn off the television. Let it sit for 5 minutes.
2. Unplug the television from the power socket. Let it sit for 30 minutes to 1 hour.
3. Unscrew and open the door that covers the projection bulb. You will usually find this door near the outlet wire. It may have up to four screws holding it in place, usually Phillips-head screws.
4. Pull out the bulb. There should be a plastic handle that you can gently pull out to remove the bulb.
5. Remove the new lamp from its packaging without touching the glass of the bulb.
6. Line up the groove on the new bulb with the groove on the bulb housing in the television.
7. Gently push in the bulb until you hear a click.
8. Screw the projection door cover back into place, then plug in the television
OK
Posted on Mar 19, 2011
Replaced the bulb is the ballast a separate piece? if so how do I change that. Had a repair man here he looked at blub,fuses,fan. cost me 180 for him to say blub which was not bad.
when replacing the bulb, it will be best to replace its ballast too. Replace the ballast. The charge quoted by the technician is moderate.
Jan 28, 2013 | Televison & Video
Dull picture how do I clean blub?
Its the small mirror in front behind the screen assembly needs cleaning. Dust gets the picture dim and dull looking.
Sep 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a toshiba 43vj33 projection ctv with a broken blub
It can be fixed but I would recommend replacing the set because the other 2 crtscould be soon to fail also. This set is old and repair will approch replacement.
Dec 01, 2009 | Toshiba Televison & Video
Change headlight blub
The whole head lamp assembly has to come out to replace the headlight bulb. Here's how to do it.
Here is a link to instructions
http://autorepair.about.com/library/a/1i/bl808i.htm
Jun 18, 2009 | 2002 Jeep Grand Cherokee
No start Sharp 56DR650
High voltage feedback levels incorrect...accordianman
Feb 27, 2008 | Televison & Video
No picture sound is good
the lamp my apper good by visuly looking at it but still could be bad. also this tv has a ballast that powers the lamp. and that could be bad...
Feb 20, 2008 | Toshiba 52HM95 52" HDTV Projection...
Samsung rear projection tv sp42w4hb
I would check the CRT socket module for Cracked solder joints. If not you may be in the early stages of the CRT shorting, If so you will need a new CRT.
Jan 04, 2008 | Televison & Video
Televison & Video Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
