Question about Gaggia Classic Espresso Machine
Need a fuse for my Gaggia Classic.
I need a fuse for my Gaggia Classic. The fuse is "Microtemp SKLAML G4A00 TF 184C." Can anyone tell me where to get it? Thank you.
  • Anonymous Dec 08, 2008
    I have a Saeco Venus with the same problem. One place to get the part is
    ATC
    email:
    info630@atconline.com
    phone:
    847.985.8383
    fax:
    847.985.1323
    Advance Technical Components, Inc.
    630 Pratt Avenue North
    Schaumburg, IL 60193-1323
  • 515 Answers
Where are you from?
Posted on Aug 03, 2008
I need a couple microtemp fuses 240 degrees C G4A00 for the wolfgang puck swivel waffle maker.
Radio Shack has a 228C and a 262C.
Google '240C thermal fuse' for online purchasing.
If you live near an urban area, try an appliance repair facility or electronics supply.
Feb 28, 2011 | Vacuums
TRYING TO FIND THERMAL FUSE. MICROTEMP G4A00 TF216C
Unfortunately, YoTeach's initial solution is in error, I believe. YoTeach mentions that typical temps for brewing water are less than 200F, and THAT seems OK, from a couple of quick searches.
However, the component that is being replaced is not necessarily working at the same temperature as the water needs to be.
The Microtemp G4A00 series has lots of temperatures, and the TF216C means, AFAIK, that Tf is 216C(elsius). See, for example, the datasheet here:
http://www.farnell.com/datasheets/625786.pdf
Tf is the temperature at which fuse opens. So, the person ACTUALLY needs a thermal fuse that opens (breaks the connection) at 216C.
Therefore, either of the two fuse temperatures mentioned: 128 & 140C, would open too soon: i.e. at too LOW a temperature.
While 216C may seem like a high temperature (420F), for the fuse to open, the thermal fuse is often very near the heating element. For comparison, I have a Gevalia CM500 coffee pot, and the thermal fuses in my particular unit are Microtemp G4A00 184C- which is about 363F.
If anyone thinks I am in error on this, please feel free to contact me: jim underscore peak at Hotmail dot com - and I'll be happy to correct this post.
Aug 29, 2009 | Krups Small Appliances Espresso Machine
We have no lights, none of switches do anything, fuse in plug is ok
Hi
There is a thermal fuse on top of the boiler that has probably blown. It is a 184c thermal fuse. You can get them from some of the internet sites like ChrisCoffee.com, Wholelattelove.com, or 1st-line.com.
Jul 29, 2009 | Gaggia Classic Espresso Machine
My gr31sb grill wont heat up, i found the microtemp g4 thermal fuse is bad by by passing it and the grill works. how do i get a new fuse?
Don't know if this helps but Radio Shack has Microtemp 10 amp G4A00 Tf 144c (144 deg Celcius) Thermal Fuses. These are the ones with the little red conical end on them. Under $2 each. I needed one to put in my toaster oven. Couldn't find the small metal clips to attach it to the wiring though. Since it is very diffucult to solder these without damaging the fuse, I'll have to recycle the old clips.
Jul 24, 2009 | George Foreman GR31SB Indoor Grill
Blown microtemp fuse
Hi man, take a look here" http://www.tod.com/productdetail.asp?ProductID=30. I think u know what to do next ...
Apr 08, 2009 | Toastmaster TOV200 Toaster Oven with...
Parts needed
contact Shriro located in NSW
Dec 15, 2008 | Gaggia Classic Espresso Machine
Whirpool rbd275yPDT11 no power after auto clean
I printed down the installation sheets. I could not locate the thermal fuse on the control panel (which was the easiest to get to without removing the oven) so I went ahead and removed the oven. The upper and lower thermal fuses were fine. I put in back into the wall and my husband found the control panel thermal fuse--it was in-line--so we tested it and it was bad. I could not find anyone online that carried this fuse-or even knew the name of it. After much hard work we finally got the info off it--Microtemp KLBALY G4A00 TE 110C. Nowhere could I find a replacement except for something I am hoping is comparable online at Goodman (?). So while I am waiting for the fuse, I went to Radio Shack who had a thermal inline fuse rated at 128C for coffee pots and hair dryers. Also got some fully insulated crimp on connectors. Hooked it up and it works--havent cooked yet--to do cookies soon to test it. So far it seems like everything is running ok. I WILL NOT EVER USE THE AUTO CLEAN again. I dont get why the company has let it lie without helping unknowing consumers
Jul 05, 2008 | Whirlpool GBD307PDS Electric Double Oven
Power doesn't come on anymore
I determined that the thermal fuse in the Gaggia Classic that I am repairing had tripped and it is not re-settable. The fuse has the following stamped on it: MICROTEMP SKMAHD G4A00 184C I believe that is what is the culprit for all of us when the "power doesn't come on." Now, what is the rating of this fuse and where can I get a replacement? The fuse is the small resistor-like, diode-like part in a clear tube mounted against the boiler, and it must be physically cut out of the line to replace it!
Apr 30, 2008 | Gaggia Classic Espresso Machine
Grill Stopped working
I am having this exact same problem. Did you ever get yours taken care of? I was going to take mine apart and look for a fuse...
Sep 24, 2006 | George Foreman G5 Indoor Grill
Gaggia Classic Espresso Machine Logo
975 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
