Question about Homelite Gas, 20 In. Bar, 46 CC, Chain Saw, UT10520
HOW DO YOU ADJUST TENSION ON CHAIN FOR HOMELITE UT10519
  • 43,501 Answers
Turn the tightener till the chain in the center of the bar at the bottom just hangs down about a 1/8"....
this will be good... too tight and the chain will not turn...too loose and it will come off...
that 1/8" is usually great for any saw...
heatman101
Posted on Mar 19, 2011
  • 1 more comment
  • snoopy3627 Mar 19, 2011
    My model number is UT10519 and it has a locking mechanism that I cannot figure how to turn since my manual is lost. Thanks
  • D. Floyd Kolb
    D. Floyd Kolb Mar 19, 2011
    Sorry, misunderstood what you were trying to find out...
    Here is the parts breakdown for your saw...
    www.mymowerparts.com/pdf/Homelite...Manuals.../PART_CAT161.pdf
    As you can see the handle (parts 4
  • D. Floyd Kolb
    Try again..
    Sorry, misunderstood what you were trying to find out... Here is the parts breakdown for your saw...
    As you can see the handle (parts 4&5) is what holds the bar tight...loosen that and you should be able to turn the tensioner adjustment and tighten the chain...if not then there is a good chance that the gears are stripped in the tensioner assembly...
    They sure don"t make 'em like they used too!!!
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
How do i replace the chain saw blade on my homelite 3514c chain saw show pictures
just unbolt the blade cover adjust screw to loosen chain and remove simple as that p.s that is the side that the bar is on hope this helps if not get back to me
Oct 06, 2013 | Homelite ZR10926 16" Chain Saw
Homelite gas chain saw 3316C How do I tighten the chain?
Lossen the bar and pull it out to adjust the chain tension
Jun 16, 2011 | Homelite Garden
I have a UT10519 and the chain keeps coming off bar. I noticed the inner guide is cut.
If the chain is showing signs of heavy wear, suggest replacing both the bar and the chain. Check the sprocket on the clutch hub for heavy wear on the teeth which will hasten wear on the chain teeth. Check chain oiling by running the saw tip near some cardboard at speed for a moment or two--it should throw off a thin line of oil. Tighten the chain until the lower run of chain just comes up to the bar, but not so tight that you can't turn the chain by hand. Hope this helps!
Jan 27, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Can you adjust clutch 16"homelite electric saw
There is not a clutch on an electric chain saw, it is direct drive when the electric motor ia activated. If the chain is binding it will stop the chain.
Nov 03, 2010 | Homelite Electric Chain Saw
Bought a Homelite 14" electric chainsaw. After using it for about 15 minutes, the chain fell off. Don't understand why. Manual did not have any instructions on how to put it back on. Returned it to...
chain will stretch with use...keep it adjusted...rest chainsaw with blade on block of wood (not running spark plug lead off) adjust chain by loosening side bolt/s then on inside at front adjust screw till chain is tight then retighting bolt/s lift chain and with gloves on check you can still turn chain by hand..
Aug 09, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I lost my manual and need to change the chain on my homelite chainsaw... never had one of these before... stihl and husky are pretty straight forward... this one not so much...
Turn the chain brake off, then remove the side cover (back off the adjustment screw several turns first). Clean the oil ports in the rear of the bar and the area around the oil outlet port. Fit the chain to the sprocket, then work the bar into the chain and pull the bar outward to tighten the chain. Fit the cover back making sure the adjustment tang drops into the large hole in the bar. Run the mounting nuts up finger tight, adjust the chain so that it doesn't droop from the bar, but allows the chain to be turned by hand, then tighten the nuts and recheck chain tension. Hope this helps!
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
How to put chain on properly
Like this:
b047417.gif Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
Have more questions or need additional help please reply below. HTH; Lou
Feb 10, 2010 | Homelite Garden
My chain came off. How do I get it back on?
Use page 25 of this downloadable manual as a guide.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=359&types=O
Loosen your tension adjust before attempting to fit the chain on the bar.
HTH
Lou
Sep 25, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Is it possible to adjust the chain break & how to do it.
hate to say this,but,there is no way to adjust the tension on the brake band.either the spring is weak or the brake band is broken.either can be changed but it's not easy.spring is under a lot of tension and can fly out when taking it apart or installing,you can get the entire cover as a unit if so desired...hope this helps,let me know
Apr 21, 2009 | Garden
Homelite Gas, 20 In. Bar, 46 CC, Chain Saw, UT10520 Logo
429 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
