Durabrand 15 inch v-chip code forgoten, for parental block. What is the master reset for this tv block.
    Guru:
  • 276 Answers
The code reset procedure is different depending on the model. Try each method until you find one that works: The default password is 0000, all zeros. To reset, most TVs have a button sequence on the TV remote like holding down the volume UP button and the channel down button at the same time for 5 secs. to reset to the default password. Some Durabrand TVs use this:
Turn the volume all the way down. Hold down the volume button and at the same time point the remote to the TV pushing the number "0". Hold until the menu appears, then release both buttons.V-chip may be reset.
Hold down MENU on the remote and VOLUME DOWN on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked.
Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Posted on Mar 19, 2011
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
I cant reset parental controls
Activated by a PIN number, you can set Parental Controls on your TV and/or cable set-top box to control the programs that can be viewed on your TV. There are three ways to block programs:
  • By Channel
  • By Rating
  • By Time Period (Not available in all areas.)
The V-Chip understands television program ratings and blocks programs based upon the rating level selected. All TV sets that are 13 inches or larger are required to incorporate the V-Chip technology. Parents set rating levels so that certain TV shows need a password to be viewed. For more information on the V-Chip and program ratings visit the FCC V-Chip site.
Several cable and satellite companies offer parental control options. They allow specific channels to be blocked so that they cannot be viewed.These companies also offer the ability to block shows based on language, violence, nudity, and rating levels. This offers more flexibility than the V-Chip.
Hope it helps ;-)
Jan 25, 2011 | Syntax LT20HVK 20 in. HD-Ready LCD...
I NEED A CODE TO WATCH CERTAIN PICTURE. CAN YOU HELP?
hi
do the following to exit the code option.
p { margin-bottom: 0.21cm; }
1.Press MENU to see the menu.
2.Press VOL+ or VOL- to highlight SET.
3.Press CH+ or CH- to select PARENTAL CONTROL.
4.Press VOL+ or VOL- to see the SECRET CODE screen.
5.Press the Number buttons to enter your four-digit secret code.
[The code will appear on the screen as you enter it. The code "0000" is the default of the
TV. If you have not set up a code previously, then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000").]
6.Press CH+ or CH- to select MASTER ENABLE, BLOCK UNRATED,or BLOCK NO RATING.
MASTER ENABLE: This is the "master switch" for Parental Control. When ON, all blocking/censoring is enabled.When OFF, all blocking/censoring is disabled.
BLOCK NO RATING: All programming with NO content advisory can be blocked if this feature is ON and MASTER ENABLE is ON.
BLOCK UNRATED: All unrated programs (based on Movie Ratings or TV Ratings) will be blocked if this feature is ON and MASTER ENABLE is ON.
7.Press VOL+ or VOL- to turn the blocking option ON or OFF.
8.Press TV/AV/EXIT to remove the menu from the screen.
ok
Jan 13, 2011 | Philips Magnavox 27MS343S 27" TV
Need code for tv remote to operate tv by the remote
Hello
You cannot change Parental
Control settings without
knowing the secret code. If
your code changes, someone
else has altered it and possibly
viewed blocked channels. Yet try the following procedure:-
Philips sets uses a four digit code to contro the V-Chip. The override code for Philips set is " 0711 "
OK.
Dec 28, 2010 | Philips Magnavox 27MS343S 27" TV
I have a old 26 inch tv and its blocked can you give the code for it please
Hello
Philips sets use a four digit code to control the V-chip. The override code for Phips Tv is ( 0711 ), although the set may say "Incorrect Code" for the first time to TRIK you. If "Incorrect Code" is displayed simply enter 0711 again. To use it Hit the Menu key to get to the menus, go Up and Down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right" arrow" key on the remote control hanset. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK Menu go to "BLOCK", and push the "Right" arrow key. Go to "BLOCKING OPTIONS' and press the "Right arrow" key. Go to "MASTER DISABLE" and press the "Right arrow" key, so that it says "MASTER DISABLE ON". The V-chip is now reset.
Ok
Nov 29, 2010 | Philips Magnavox 27MS343S 27" TV
Master code to the v-chip parental control of an
Good Luck. These Rca tv a a pain, Call RCa and find out if they can send you a manuel.
Mar 18, 2010 | RCA F19262 19" TV
Sampo LME-17S1 TV/Monitor w/RC-235B Remote-V-Chip - No Code
Master V chip over ride code is 8,4,8,4,100 (use the 100 button not 1,0,0) you should be good to go!
May 23, 2009 | Sampo LME-17S1 Television
Password for durabrand tv
I found this and it worked for my durabrand DU1301A t.v.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Comment by techman, posted on Feb 11, 2008 You need the original remote or an original replacement to use this procedure.
Thx to techman
May 25, 2008 | Televison & Video
V chip
The V-chip has a 4 digit numerical password in order to keep older children from changing its settings. However, it can be overridden by savvier youth who read the television's manual to find out how to reset the password to 0000 (built into the V-chip in case the parents themselves forget the password that they set).
Oct 03, 2007 | Durabrand DWT1905 TV
New Used tv
Yes there is my friend! Follow these instructions and it will work for you! Philips and Magnavox: Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jun 21, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
524 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
