Question about KitchenAid KGRA806PSS Gas Kitchen Range
I have a gas KA stove top - the electric igniters now click (often all of them in unison) even when the gas is off - just starting one burner makes them all stop - only way to quiet them is to pull the plug which is not in a convenient place - what should I do?
  • 2,382 Answers
Hi, is your range gas with electric ignition? And are the igniters constantly clicking with the burners off? If so it sounds like you may have spilled liquids into the electric switches at the burner control knobs causing them to short. This is a common problem and the best fix is to unplug the range from the power and let the range dry out for 24 to 48 hours. Sometimes using a hairdryer can speed up the drying process. If you did not spill or get any liquids into the burner ignition switches then there is a posibillity that one of the switches is defective. You would need to test each igniter switch with a continuity tester and the burner knobs in the off position(power unplugged for safety) to see which switch is defective and replace that switch.
Posted on Mar 19, 2011
The electric panel on my smooth top stove just went out with a popping sound rendering the oven unusable but the stove top burners are working.............what could have happened and is it worth it to get...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 21, 2010 | Kenmore 95423 Stainless Steel Electric...
I have a 30" stainless steel cand black gas range with electronic oven control and self ignited burners. For some reason the burners won't self ignite they don't even spark but the gas is comin out. What...
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 21, 2010 | Frigidaire FGF337EC Stainless Steel Gas...
Stove top ignitors do not ignite but oven does.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Spark ignitors went on stove top
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
I can't get one of my burners to light on my ge gas stove. It clicks and emits gas, but no flame.
Dec 17, 2009 | Avanti G20AW-1 Gas Kitchen Range
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Gas burners/electronic ignition
Jan 26, 2009 | Tappan TGF657 Gas Kitchen Range
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
KitchenAid KGRA806PSS Gas Kitchen Range Logo
54 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
