Question about LG WM-2277HW Front Load Washer
I took apart the drain pump but i forgot where the 2 wires connecting to it go. i can't remember if the red one goes on the inside or the black one does. can you please help?
  • 4 more comments
  • sjsmcgraw12 Mar 19, 2011
    Thank you so much!!!! i really appreciate it. you just saved me $100! thank you again!
    ok i fixed the wires but now how does it go back on the rest of the part? does the round side go on the bottom or top? does it lay on its side or does the flat side go on the bottom?
    thank you
    how can both go on the bottom?
    ok great! thank you so much
    how do i get the spring/retainer back around the gasket on the door?
    yes. he knew what he was talking about. Thank you so much for your help!
    Brigadier General:
  • 3,513 Answers
Its the black wire that goes inside. For a detailed diagram please check a sample article attached in the link:
http://www.applianceaid.com/frigidaire_frontload_washer2.html
Thanks
Sonjoy
Posted on Mar 19, 2011
  • 1 more comment
  • Aparajita Batabyal
    Aparajita Batabyal Mar 19, 2011
    Thanks. Please accept the solution and rate it.
    Thanks
    The round side goes on the bottom. The flat side go on the bottom
    Sorry my bad the second one will lay at the side.
Pentair Superflo 1 hp. two speed
common white, high black to #2 low red to #3 green ground
Aug 20, 2017 | Pentair Garden
I am trying to wire a new Emerson 230v pool pump to a timer. The pump has 2 red wires and 1 green wire coming from it. The timer has 3 wire terminals. The receptacle has 1 black wire, 1 white wire and 1...
You really need a 2-pole timer -- 2 wires in and 2 out. In that case the Black/White from the receptacle goes to the 2 "in" terminals and the 2 red wires from the pump go to the 2 "out" terminals. The WHITE wire from the receptacle goes nowhere - tape it off. The Bare wire from the receptacle goes to the GREEN (ground) wire on the pump.
A single-pole timer can be used, but in that case, you ALWAYS have 110 v on one side of the pump. Not safe, and not code compliant.
May 27, 2017 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
I Got a motion sensor light on my outside porch well i took it all apart to repaint it now i am confused as to were all the wires go i have 2 that come off lamp post black and white and 3 that come of...
all white wires go together,the hot wire from the switch goes to the black of the sensor and the red connects to the black wire from the light sockets
Jun 12, 2011 | Electrical Supplies
I need a wiring diagram for hayward pool filter model K48m2n11b3
Are you trying to wire a pool pump?
I found manuals at the Haywood site > I saw nothing for K48m2n11b or anything close to that number
http://www.haywardnet.com/inground/products/manuals.cfm
But lets work on the problem and see if I can give you some help:
After opening a few manual and searching for the word 'volt' and 'pump' ... each manual talks about 'pumps' generically, as if the pump is a separate purchase item.
Lower down on the manual page they have a list of pool pumps. A search for the word 'volt' inside the pump manuals says 'match supply voltage to motor nameplate voltage.'
As you know, each electric device has a label showing voltage, wattage, etc. Your pump should show 120Volts or 240V. I didn't see any mention of 3 phase wiring, so I assume your Haywood pump runs on typical residential wiring? And that you are not using 440Volt or 3 phase.
The 120Volt pump will have a black, white and bare ground.
The 240Volt pump will probably have a black, white, red and bare ground
The 240Volt pump could have a black white and bare ground
First the 120V pump:
The 120Volt line from your breaker box will have a black Hot wire, white Neutral wire and bare ground >>> this wire connects color-to-color with pool pump
Next the 240V pump with black, white, red and bare ground
a) The 240Volt line from your breaker box can have the same 4 wires, in which case they connect color-to-color
b) The 240Volt line from your breaker box could have a black white and bare ground, in which case the black goes to black, the white goes to red, the bare coppers are connected, the white pump wire is capped off and not used. If pump does not operate with this wiring, another line from the breaker with wires that match pump might be necessary.
The 240V pump with black white and bare ground
a) The 240Volt line from breaker can have black, white, red and bare ground, in which case the black goes to black, the red goes to white, bare grounds are connected, the white wire is capped off
b) The 240Volt line from from breaker can have black white and bare ground, and this connects color-to-color to the pump
HOW do you know if line from breaker is 120V or 240V?
If you know which breaker wire is connected to, then it's easy
If you do not know which breaker
-turn off power
-separate wires so they can be tested
-use ordinary tester
-stand on dry boards
-tape tester leads to sticks so hands are away from power
-turn on power
-test each wire to bare copper
-tester lights up on Hot wire
-120V line will have 1 Hot wire
-240V line will have 2 Hot wires
Oct 18, 2010 | Garden
LOOSE BLACK WIRE GOES WHERE?
It should be connected to the red wire, and has to be completely inside the motor, inside the cable and this last, bolted properly on top, that is very important to prevent electrical shock or damage to the pump,
Have a good day,
Sep 04, 2010 | Tsurumi Pump s Submersible Trash Pump -...
Ive taken apart a simpson delta 402 (0036A402P020) and forgot to take note of which side of the pump the black and white wires went to, I am wondering if anyone could tell me the correct placement for...
Hi just read your posting.The 2 wires you mentioned definitely came from the 2 terminals of the pump,Is that correct?Does your fan have a fan attached to it?Now if you have answered yes to both questions then the 2 wires can go to any of the terminals of the pump as it does not matter which way round they go.In other words the wires are interchangeable and it wont change the direction of the pump.Just to be sure, the black wire goes to one terminal and the white wire goes to the other terminal.Hope this helps and please reply to tell me how you got on or if you need further help.
Jun 20, 2010 | Washing Machines
I have 2 type r 12s and i forgot how the wires go when i took them out of the box. by wires i mean the two wires that connect from the sub to the round terminal in the back of the box. can someone show me...
If you want the speakers wired in parallel, then just make sure positive(red) to Positive(red), and negative(black) to Negative(black) .With 2 speakers, just jump from one speaker to the other....positive red to red, and negative black to black..
Apr 10, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
Belkin 1500va (uses 2 - 12v 7ah batteries)
check out this picture, it shows the 2 batteries wired up.
Notice that the batteries are flipped opposite of each other.
So from left to right its: bottom red, bottom black, top black, top red
http://www.pcstats.com/articleview.cfm?articleid=1092&page=2
Between the 2 batteries there is 1 red to black connection.
Then black to black-wire to circuit board
and red to red-wire to circuit board.
Aug 22, 2009 | Belkin (F6C800-UNV-PL) UPS System
WM3431HW not drying
hi Of all washing machine parts, the water pump probably takes the most punishment, because it is constantly in use. When the pump fails, you can hear or see the trouble: a loud rumbling inside the machine, or a failure of the water to drain out of the tub. Here's what you can do to fix the problem:
©2006 Publications International, Ltd.
Take the pump apart and clean
away all debris inside the pump.
Also clear away debris from
the water tubes.
Step 1: Check the drain hoses to make sure they are draining properly. Remove the water supply hoses from the back of the washer. With long-nosed pliers, extract the filter screens from the valve ports in the washer or from the hoses themselves. Wash the screens thoroughly. Then replace them and reattach the hoses. If the machine still rumbles or doesn't drain, examine the pump.
Step 2: To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the bottom of the machine, but with the unit tipped on its front it's easier to remove the pump through the back than through the bottom of the washer.
Step 3: Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them. Then try the machine again to see if this kinking was causing the problem. If the machine still doesn't drain, you'll have to remove the water pump.
Step 4: To remove the pump, loosen the bolt that holds the drive belt taut and move the washer motor on the bracket to loosen the belt. Move the motor out of the way and unbolt the pump; it's usually held by two or three hex-head bolts located on the bottom of the pump housing. As you loosen the last mounting bolt, support the pump with your hand. Then lift the pump out of the washer.
Step 5: You should take the pump apart if you can, because the trouble could be lint, dirt, or pieces of cloth or paper clogging the pump impeller. Clean away all debris inside the pump and clear any debris out of the water tubes. Then reassemble the pump. Hook up the pump again and test it. If cleaning the pump doesn't put it back into working order, or if the pump housing can't be removed, replace the pump with a new one of the same kind.
Step 6: To install the new pump, set it into position and connect the mounting bolts to the pump housing. Move the motor back into position. Tighten the drive belt on the motor by prying it taut with a hammer handle or pry bar; it should give about 1/2 inch when you press on it at the center point between the two pulleys.
Step 7: Reconnect the hoses leading to the pump.
Oct 07, 2008 | LG Washing Machines
Machine will not drain and spin
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/4681EA2001D/New.aspx?ModelMfgName=LG+Electronics+Incorporated&ModelBrandName=LG+Electronics%2fZenith&ModelNumber=WM3431HW
you need a new one of these. i took mine COMPLETELY apart and found the impeller jammed. the impeller is a magnet in a sealed plastic carrier with an electro magnet around it. the electro magnet energizes , the two opposing fields spin the inner magnet ( just like a fish tank filter good idea actually!) the inner magnet on mine had a slight crack from factory causing vibration and allowing debris past the seal then jamming the impeller. to check yours drain it with the small drain tube, then get a towel or two and place around the unit at the floor.pull the large black drain cover off and after the gushing tidal wave look inside. you will see the white impeller. try turning it with w screw driver , pen or whatever. you may be able to remove and then clean / reassemble and be good as new. i only needed two tools to tear the machine apart. a Phillips screwdriver and pliers to get the clamps on the pump (2) and the clamp back on the door to drum gasket.
Nov 06, 2007 | Whirlpool AWM5145/2 Front Load Washer
LG WM-2277HW Front Load Washer Logo
95 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
