Question about Mach Speed Eclipse 180 MP3 Player
My player wont let me put music on it it says directory or file cannot be created
  • 109 Answers
You shuild download a copy of apple i-tune and copy the music using i-tune software...
Posted on Mar 19, 2011
USAGE OF MEMORY CARD
I am thinking that you need to put the files into a specific directory. For example, for my HTC Hero, I have to create a directory on my SD card named Music. Other brands may have different requirements for the phone to recognize your media files.
Check with your phone's manual or do a Google search.
Good luck.
Mar 23, 2010 | PNY 2GB microSD Memory Card
MY MEMOREX MP TOUCH WONT TURN OFF, HELP!
get a small paperclip. unwind the outer part so you have a straight piece sticking out at a 90degree angle. insert the end of the straight paperclip into the small hole on the lower right side of the player ~ this is the RESET button. it does not delete any content; it just interrupts power. the only thing you will have to do is reset your TIME settings. this SHOULD work. you don't have to, but you can re-create the 'MicRecord' Music' and 'Playlists' directories on the ROOT of the player. re-copy your music into the MUSIC directory.
Jan 16, 2010 | Memorex MMP9490 Digital Media Player
How do you simply just put files onto this i can get them on to the flash drive but it wont read them as music files
Turn on the player_slide power switch up_hold about 3 seconds, release
Silvania boots, then system Menu appears.
Select Music icon
Scroll with <> to highligh hidden MediaLib Update
player rebuilds Music media database used in player
use Dir List to open the browser. Navigate to location of your music files
Use Explorer Icon to browse directory list and use Delete button (square with X) to delete Selected file in Explorer view.
In My Computer, Use Properties to Name (Label) your drives. You see name given in My Computer, makes much easier to locate files. For easier browsing in Windows try a Toolbar for My Computer(XP) or Computer (Vista, 7) to browse your devices (I have a Computer toolbar on the taskbar of Every Computer I use)
Open SMPK8858 in my computer, you see RECORDING folder
This was the only folder on mine when I started, and Sealed, Brand New unit came with NO SOFTWARE and microscopic manual
Create new file structure for storing your PHOTOS, VIDEOS, Ebooks etc. Don't place everything in one folder, use logical folders to store your files. Drag and Drop FILES into your folders in my computer, or create a shortcut on desktop to access your device when connected.
Dec 04, 2009 | Sylvania SMPK8858 MP3 Player
Computer doesn't regonize or charge my mp3 player
Make sure the player is OFF before you plug it in and while you transfer you music or charging. Sounds odd but that is it in a nut shell. But here is step by step:
In essence it is as easy as copying files from one folder on your computer into the other.
1. Make sure your player is turned “OFF”.
Important Note: Having player “ON” when plugging and unplugging from computer may delete all files on the player.
2. Connect your player to any USB port on your computer via provided USB cable.
3. Computer will find it as a removable external hard drive.
4. Double click this drive to open it.
5. Open your music/video/text/image files folder in another window.
6. “Drag-and-Drop” your files from your directory on the computer to the root directory of the player.
7. Once the files are copied – disconnect the player from computer.
8. Turn KEO "ON" and go to the desired Mode ("Music", "Movie", etc..) Your newly-copied files should be visible there among other media files preloaded on the player. Use arrow buttons to scroll through them.
IMPORTANT NOTE!
Avoid creating separate folders for every 2-3 songs. Preferably put all audio files in he same “MUSIC” folder, or sort them by "Artist Names" folders or just store all in the root directory (do the same with VIDEO files).
KEO does not support playlists at this time and excessive amount of 2-3 levels of folders may noticeably slow down the operational speed of the unit.
Sep 08, 2009 | Ice Tech KEO MP3 Player
The Sharper Image 2GB Mp3 (1612788) Is Not Copying Music Files
The Sharper image 2gb player will only allow 131 entries in the root directory. Create a new folder, just like on your computer, and then add music files to that folder. I have not tested if there is a file limit in a new folder.
Jun 30, 2009 | Sharper Image 1612788 MP3 Player
I lost my disc can i still download
You can put music on it by doing the following (assuming vista/XP environment):
Connect it to your PC using the provided USB cable.
Open windows explorer and navigate to your Sansa Clip.
Click through "sansa clip", "internal memory" to the "music" directory.
Drag and drop MP3/wav files to this directory. Feel free to create subdirectories.
Your music will be accessible after doing this.
Be aware that the clip ignores your directories. It will look for artist, album, and title tags to categorize your tracks. You may have to look for your tracks in the "unknown" album directory when playing if your tracks don't have these (ID3?) tags.
Good Luck!
JakeE333
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
EnV2 does not recognize MP3 files on micro SD card
This was tricky, but I was able to get MP3 files recognized on my daugter's phone.
First, the MicroSD card needs to be formatted by the phone. The phone requres a special directory structure to be created. You may be able to do this manually, but I did it by letting the phone initialize the card. To do this, insert the MicroSD card. Make sure you push it all the way in.
Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 3 Card Memory. The phone should recognize the card and initialize it by creating the special directories for My Music, My Videos, My Sounds, etc.
Then put the card into your PC and copy your MP3 files to the My Music directory on the card. I could not get the phone to recognize sub folders, so make sure you copy everything directly to the My Music directory and not the one under it.
Now the card is ready, you have to tell the phone to use your card memory and not its internal memory for these items. Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 1 Save Options. Pick Pictures, Video, and Sounds and set the phone to use Card memory for each.
Now you can import the music into the music player on the phone. Go to menu 5 Media Center. Menu 1 Music & tones. Menu 4 My Music. The music player should then Import yhour music into the player and it should now be playable.
(I think these accurately reflect what I did)
You can also go to 9 Settings, 9 Memory, 3 Card Memory, 4 My Music to view your music.
Jan 01, 2009 | Cell Phones
Music Input
you have to put only mp3 and wma songs on it..
Mar 11, 2008 | SanDisk Sansa c200 MP3 Player
PSP
  1. on the PSP go to settings -> USB connection
  2. Go to my computer, a new removeable drive should appear after a few seconds
  3. put music files in the MUSIC folder and videos in the VIDEO folder (or create them yourself if needed)
  4. go back to the menu on the psp, you should be able to watch/listen to the files you added
Note: The psp does not support all video and music file formats
so you may have to convert them if they wont run
You can also get programs like "psp video 9" which can automatically convert videos for you and put them in the correct folders.
Mar 08, 2008 | Sony PlayStation Portable (PSP) Console
Sansa error 0x80070052
code error x080070052 while sending document to flash usb
Feb 11, 2008 | SanDisk Sansa c200 MP3 Player
Mach Speed Eclipse 180 MP3 Player Logo
131 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
