Question about Alpine IVA-D310 Car DVD Player
Parking Brake I've got a 2007 GMC P.U. and i need to know where and what color the parking brake wire is and at.Thanks James
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
If it is a GMC Canyon, then the wire is light blue at the brake pedal harness. Be sure to test this wire before connecting as this wire will test 12V+ when the pedal is pushed in. The parking brake wire is also light blue and can be found at the parking brake switch. Peripheral electronics makes a box called a PTR-7 which can be connected to the alpine and serves the purpose of the brake connections for the video bypassing of the unit. Hope this helps.
Posted on Aug 03, 2008
How do i adjust parking brake on a 2007 gmc dual wheel 3500 truck
need to go under the vehicle around the drivers seat will see the cable ,adjuster and 2 to 1 connectors for the parking brake
Apr 18, 2017 | GMC Cars & Trucks
Parking brake light is on
You may have play in the park brake pedal due to park brake cables needing servive/repair. If you pull up on the park brake pedal when the light is on... will it go out? Another reason for this light to come on is low brake fluid. Have the level checked
Apr 05, 2015 | Cars & Trucks
Where is the parking brake switch located on a 2007 GMC Sierra Classic? I am trying to hook up the parking brake wire and can't seem to find it.
Why don't you just install a toggle switch? Place one end on the parking brake wire from the Pioneer unit and the other end to ground. This replicates putting the parking brake on and enables you to watch movies.
Sep 15, 2010 | Pioneer Car Audio & Video
I need to be walked through installing a Bulldog self learning anti theft bypass module 791 on 2007 GMC Sierra 2500 HD SLE. Thanks!
Here have information about #791 bypass module: Bulldogsecurity Model791
IF YOUR REMOTE STARTER IS CLICKING AND/OR FLASHING THE PARKING LIGHTS AND IS NOT RESPONDING TO THE REMOTE, IT IS IN SAFE MODE AND NEEDS TO BE INITIALIZED BY DOING THE FOLLOWING:
If you have a 4 button remote, you must ground the black/blue hood pin wire (raise hood if hood switch is installed). Apply 12volts to blue/black brake wire (press and hold brake pedal if wire is installed). Press and hold any button on your remote until clicking and flashing stops. Unit will now respond to the remote. Remove ground from hood pin wire and voltage from brake wire. If you have a 2 button remote, hold brake and press any button on the remote until clicking and flashing stops.
ADDENDUM
If you have an RS1100 or RS1200 and your vehicle runs for several seconds, shuts off, restarts, runs, and shuts off again, perform the following step: Connect the Black/White tach wire (from the 16 pin plug) to the heavy gauge White Ignition 1 wire and program the unit for Tach Mode (bottom of page 19).
Witch model alarm have your vehicle?
Good luck.
Mar 10, 2010 | GMC Sierra 2500HD Cars & Trucks
My 2007 GMC Z71 Has no taillights or license plate lights. However my brake , hazard, and turn signals all work. What happened?
The tailight markers and plate lights are wired together. A fuse to the marker lights or sometimes called,park lights, may be blown. You may have a naked hot wire rubbing metal. Sometimes SUV's have trouble with trailer light plus also that ground out the circuit.
Jan 12, 2010 | 2007 GMC Sierra Classic
Turns over but wont start wont come out of park in this mode
brake switch may be bad and the truck doesn't know you are depressing the brake to pull truck out of park
Sep 24, 2009 | 2007 GMC Envoy Denali
Wire harness for trailer
You will need a test light, don't worry about the colors. Four wires, one for left turn signal, one for right turn signal, one for parking lights, and one is ground(usually black). Hook up ground, turn on trucks left signal and hookup to one of trailers other three wires, you will either light up the correct light or wrong one just continue til lights match coming off your truck to what you want to light up. And brake lights are left and right signal, so if you do signals the brake light will work. I can explain further if you need help.
May 23, 2009 | 2000 GMC Jimmy
Wiring diagram or fuse box diagram-2007 GMC Envoy Denali
Hi there;
Here is the wiring diagram for the trailer wiring for your truck.
Hope this helps
Farrout!
Mar 07, 2009 | 2007 GMC Envoy Denali
The video wont work but the audio work perfectly fine.
the reason your seeing that message is because there is a wire on the head unit that needs to be connected to the parking brake switch on your car. the wire your looking for is a light green color that needs to be spliced into the positive side of the parking brake switch. once you hook that wire up the video portion of the head unit will work but you have to have the car in park with the parking brake applied. if you comment back with the make and model of car your driving i might be able to tell you where the parking brake switch is and what color wire to splice the light green wire into.
Feb 17, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Parking brake bypass
apply 12v positive to the wire to bypass the parking brake
Dec 12, 2008 | Jensen VM9510 Car DVD Player
Alpine IVA-D310 Car DVD Player Logo
232 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
