Spin cycle problem Maytag washer model MAH 3000 AWA
When the washer gets to the spion cycle it will not spin. It appears this is quite common with the Neptune washer. You said replace the wax motor door latch. Are you referring to this problem? I try to hand wring out the water but i am afraid this is going to over load my dryer with the excess weight. It has been a very good washer . Do not want to invest a lot of money as some of the people have written to you. Will appreciate any help you can give me. Thanks Walter
  • 1,122 Answers
All neptune washers have a defective wax motor door switch and need to be replaced,you can get one on ebay for $8 and the guy even shows you in pictures on his sight how to install it,if it is not that then check the motor control board front bottom right behind panel,also check the main control board on the top back of washer head,look for any burn spots on both boards ,let me know,thanks-mike
Posted on Aug 02, 2008
Maytag Neptune MAH-1 front load washer won't spin in some cycles I use often. it spins at the end of the cycle and in cycles I do not use often. it spins in the spin cycle when I run that cycle
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Mar 16, 2015 | Maytag Washing Machines
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Does sound like it's not balanced properly, or maybe it's set on drip dry instead of spin , basic solution i know but often the best lol ,
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
My Maytag MAH-24 Washer suddenly started making a clunking grinding sound in the middle of the spin cycle.
The rear tub bearing is going out, and the cost starts normally about the 450 and up range,
May 27, 2012 | Maytag MAH2400A Front Load Washer
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Washer will not spin
Sounds like it could either be an electrical problem, with the signal from the timer control board getting to the gear box,,, or it could be the gearbox itself.
Mar 12, 2009 | Maytag 22 Cycles Topload washer, SAV365Z
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Won't spin
you need to replace the wax motor door latch as i have read all of them have to be updated due to defect,if you need more info let me know-mike
Jun 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
755 people viewed this question
Top Washing Machines Experts
