Question about Ovens
I have made a birthday sponge (12") for tomorrow. I have got a layer of buttercream in the middle and I covered the rest in buttercream to seal it. I wanted to put on marzipan and fondant icing and I covered it in warm apricot jam and put marzipan on the top. I haven't put the fondant on yet as I am worried now that it seems wet - it is for a 70th birthday for tomorrow. Please help before I go any further.
  • Ovens Master
  • 8,220 Answers
Seems to me you need to put the cake in the ice box after each step and allow the cake to set before going to the next steps.
Posted on Mar 19, 2011
I have a defy petit chef thermofan oven. It is soiled between the glass layers of the door. How can I clean it, Please?
The glass panels are thermally sealed. Cleaning is not recommended maintenance.
Jul 17, 2017 | Ovens
Tip
Kitchen Appliances Maintenance Tips
All natural oven cleaner
  1. gently scrap of the burned on food with help of plastic scraper.
  2. create a paste of baking soda with water. 5 table spoon of water per cup of baking soda.
  3. wipe on to the top and inside the stove and let it rest for 12 hours.
  4. use a damp sponge to wipe of the dried paste. Use vinegar to make the job easier.
on Nov 08, 2016 | Ovens
Whirlpool generation 2000 wont reset after powercut. Just says STOP.
Turn left knob to dash mark then turn right knob on normally see if this works. Hope this helps.
Dec 31, 2013 | Whirlpool Ovens
Outside door glass has slid down
Sounds like the door gasket/seal has pulled away from the rest of the door frame and layers. You might be able to take the door off of the hinges, and cabinet, and take apart the layers to readjust.
Dec 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Nov 22, 2011 | Neff Ovens
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
G E Profile walloven
Unfortunately, you will probably have to call for service. It is a very detailed task with many screws, seals and insulation involved.
Sep 26, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
124 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
