Question about Microwave Ovens
Just wanted to know if I have to take the unit down or if I can get at the turntable motor from underneath the unit. The turntable still goes around but it is making a noise and not at a constant speed. It is a Whirlpool model # GH4155XPB3.
    Brigadier General:
  • 8,909 Answers
On most microwave ovens, the motor is accessed from an inspection cover, underside of the oven.
Posted on Mar 19, 2011
My microwave oven works, but the turntable stopped turning. How can I repair this?
turntables are turned by a rubber belt from a small motor
have an appliance service center check it out and get a quote
Dec 24, 2015 | LG Microwave Ovens
Turntable does not turn (work). model:JVM3660SD001
have you check if the unit has the power... & also check if all the settings was made..
Jun 13, 2008 | GE Microwave Ovens
Turntable doesn't rotate
Your turntable motor need replacement. tip upside down with dish removed and gain access to turntable motor from underneath.(remove power plug before you start working on the m/wave.) 2 screws hold the small t/table motor in place.Unscrew both and pull motor upwards. Quote the info on the motor for a replacement. I find cooking isnt effected in any wayexcept if you want to bake things like cakes. It then requires the t/table motor.
May 21, 2010 | Panasonic NN-T993SF Microwave Oven
Turntable does not spin but everything else seem to work just fine
It is likely the belt broke or came off or degraded. Take cover off unit and check belt underneath.
Apr 04, 2010 | Frigidaire FMV145K Microwave Oven
The turntable does not move around when the microwave is on
ths is probably a failed motor they can go open circuit i have had a few where the fixing screws underneath that hold the motor fall out severing the drive spigot ,check if the spigot turns under the glass turntable if hard to turn will be motor failed cheap easy fix.
Mar 19, 2010 | Neff H5642 Convection / Microwave Oven
My turntable will not rotate. I've checked the piece underneath and it appears to on correctly.
it could be be bad turntable motor.to chk this open up the bottom plate by removing the screws around it.then disconnect the wire connector from the motor.start the unit and chk the voltage with multimeter.if u read voltage then motor needs to be replaced.make sure turntable function is on and not off at the control.if there is no power at the connector then it could be control.chk for any loose wires etc.
Aug 16, 2009 | GE Advantium 120 Convection/Microwave Oven
I'm trying to fix my turntable
Most units have a acess panel on the bottom of unit.If not it would be a cut out around where the motor is.I would say try that if to much work let me know
May 08, 2009 | Sharp R-320HQ Microwave Oven
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Turntable won't turn anymore
The turntable has a drive motor which is located behind the panel that covers the BOTTOM of the oven. It could be that this small drive motor has failed. Replacing it should be simple and doesn't cost much. If the oven is mounted, you can leave it in place in most cases and just remove the bottom panel. Make sure the unit is UNPLUGGED before servicing, however. Please post back with your complete model number (located around the door opening) so I can be sure. I'm having a hard time locating any parts info and want to make sure I give you the right advice.
Mar 31, 2008 | Kenmore 64282 Convection/Microwave Oven
Spacemaker 1800 Turntable
If the noise goes away when you turn the turntable off, it sounds like you have a turntable drive motor that is going bad. They are fairly easy to replace and not terribly expensive. You can access the motor by leaving the oven in place and UNPLUGGED. Remove the bottom panel. You will need to remove the turntable coupler (the plastic piece that spins the glass carousel) and remove a few screws in order for the motor to come out through the bottom of the oven. There should also be a quick connect plug that plugs into the motor. The motor runs about $35 and the turntable coupler (if you wish to replace it as well), runs about $8. The part numbers are 769741 and 769278, respectively at repairclinic.com. I hope this helps you.
Jul 07, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
