Question about KitchenAid Dryers
My dryer makes a noise but dont spin around whats wrong
The drive belt is brobably broke and you will have to replace it.it goes around your drum and to the motor.
Posted on Mar 20, 2011
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Drum not turning, just belt spinning around. Drum making noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 05, 2011 | LG DLE2532W Electric Dryer
I have a indusrial admarial 10g and it makes a noise when spinning it still heats up to dry clothes could you tell me whats wrong please and to to get into it to fix it thank youi
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 18, 2010 | Dryers
My dryer is making a very loud BOOMING noise
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 08, 2010 | Whirlpool LER5636P Electric Dryer
Dryer is making a banging noise? Sounds like
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 17, 2010 | Maytag MDE9700AYM Electric Dryer
Noise when dryer is spinning
The drum rides on some roller wheels to allow it to rotate and give it support. They have bearings in them that fail and begin to make noise. Replace the roller that is bad. You have to access the drum by removing the front of the machine, support the drum and find the noisy roller.
Jul 13, 2009 | Kenmore 63942 Dryer
Beko tumble dryer was making strange noise now no heat but still spinning
How old is your dryer? strage noise usually take place if the unit is old and worn out. I dont know of any washer or dryer doesn't make noise after years of using. The more you use the more ware and tear and noise come from the unit. Noise can be the belt loose or tumbler padding or flange, connected to a simple bushing is worn out, making the unit woobily noisy. No heat mean your heating elements probably burnt out need replacing which will cost 80-100 bucks. its fairly easy to replace once you remove the back cover. To find out what making that noise, the best thing to do is run the dryer with the back cover off by look and listhen and see what making that noise.
Jul 08, 2009 | Dryers
Maytag sde3606ayw make loud screeching noise
You Need to replace the drum Rollers. They cost around 10.00 Each online, 20.00 Each at your Dealer. Please Dont try to Put Oil on The Roller Shaft. It will come off and make its Way To Your Clothing. Martin Appliance Sells Specific Oil for the shaft for around 8.00. Thanks Sean
Dec 06, 2008 | Maytag Neptune MDE5500AY Electric Dryer
The washing unit makes a high pitched loud noise
Check to see if you have a bra underwire or nail stuck in the spin tub. Look around inside the tub looking for something stuck in one of the holes. Dont use the machine until you find the problem or you cut the tub in half with like a nail or screw and then the machine has to be rebuilt $$$$
You may have other problems, However start here. Let me know if you have other questions
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryer making noise like pulley in going out
most dryers you can remove the back panel and run it.but some have the elements attached to them so it makes it hard to test,dont know what make and model you have.it could also be a motor bearing or drum bearing.hope this helps.
Mar 15, 2008 | Dryers
Dryers Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
