Question about Onkyo TX-8211 Receiver
TX-8211 FM Stereo/AM Receiver All has been fine
TX-8211 FM Stereo/AM Receiver All has been fine for years, I just readjusted speaker wires. Now, the unit is on & in just a matter of seconds the display changes to PROTECT & all goes off.
    Genius:
  • 1,043 Answers
The protection circuit in your receiver can be tripped by reversing the wires of the speakers, or also by making the wires to the speakers too long. If you are using regular speaker wire, it won't take much of it to raise the resistance to the point of tripping the circuit. However, if you are using premium wire there shouldn't be a problem. The next thing to check would be the polarity of the speakers. Make sure that you are using the same wires for the "-" and "+" sides of the speaker connections. If all of the connections to the speakers are correct the next thing to try is to disconnect the speakers from the receiver and then turn the unit on. If the protection circuit doesn't kick in then the speakers are the problem. If the protection circuit does still kick in then you either have a short, or something is overheating. At this point, unless you have the experience, tools, and the service manual, it would be time to take the receiver in to an Onkyo repair center in your area.
If you do have the tools and experience you can download a copy of the service manual from the following link:
http://www.givemefile.net/smanuals/radios/onkyo/tx-8211.html
The file is in the pdf format. If you don't already have the Adobe Free Reader you can download it from this website:
http://get.adobe.com/reader/
Just click on the orange box that has the word DOWNLOAD in it. If you save the file to your Desktop all you have to do is double-click the icon that it creates and the reader will install itself. You can then double-click the file for your manual and it will automatically load the reader and display itself in the reader.
Posted on Mar 19, 2011
    Sergeant:
  • 162 Answers
Make sure that somehow the wires didn't get loose from the speakers in the back. Protect means that it's overloaded. Did you change the plus wires with minus wires maybe. Check to make sure all the wires are good.
The r speakers don"t work
First check balance and fade to ensure it is getting a signal. If that's OK then check wiring.
Dec 12, 2013 | Onkyo TX-8211 Receiver
Onkyo tx 8211 receiver shut off problems
Check all of your speaker wires and speaker turminals. I bet there is a short.
Apr 26, 2012 | Onkyo TX-8211 Receiver
TX-8211 FM Stereo/AM Receiver Display changes to PROTECT & shuts the power
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 19, 2011 | Onkyo TX-8211 Receiver
I have a TX-8211 but I am out of town looking at Internet Radio tuners. Can you tell me what type of inputs are on the Onkyo? I know it has the black/red spring loaded wire inputs but are there other...
Your tuner will be the limiting factor regarding sound. The Onkyo accepts any stereo analog input via RCA connectors, period.
Those "black/red spring loaded wire inputs" are speaker outputs and if you hook one of those to an innocent audio device's Line In connections you might kiss it all goodbye.
Read the manual...
http://www.retrevo.com/support/Onkyo-TX-8211-Receivers-manual/id/365ci165/t/2/
Feb 01, 2011 | Onkyo TX-8211 Receiver
Onkyo TX 8211 protection mode is activated and i want to know how to deactivate it????
Eliminate the short or overheating problem it thinks exists. Disconnect all speakers first to see if one of them is the culprit. If it's internal, take it to a shop.
Jan 19, 2010 | Onkyo TX-8211 Receiver
Vollume trouble
the system protect is usually displayed when a condition of short or shorting is occurring in the speaker wiring or the voice coil of any of your speakers.... thte circuit of you reciever is trying to protect itself and you from a very costly repair,,,so it you have another set of speakers try to use them and see if the condition still exists and if it does the problem is in the output section of the receiver,,,and if the protect no longer exists you have fixed your problem,,,good luck
Apr 07, 2007 | Onkyo TX-8211 Receiver
Onkyo TX-DS484 Receiver
Did you set all your parameters (see manual, page 15)? After that, you can then also change the levels of each speaker (page 16) also.
Feb 12, 2007 | Onkyo TX-DS484 Receiver
Onkyo TX-8211 Receiver Logo
215 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
