I'm subscribed to AT&T U-Verse, have their remote, I need a code to simplyfied the joint use of this remote on a Olevia 237 T model
    Genius:
  • 1,043 Answers
The only code listed for the AT&T U-Verse remote for Olevia is 1420. If that particular code does not work on your TV you will have to do a manual scan. What this will do is cycle your remote through all of the TV codes it can create. Just follow these steps:
1) Turn your TV on manually. Hold down the TV button on the U-Verse remote.
2) As you are holding the TV button down, press and release the OK button.
3) All of the mode keys on the remote should flash twice. This will let you know that you did the above steps correctly. If they don't flash repeat steps 1 & 2 above.
4) Once the mode keys flash twice enter code 922. The TV button should flash twice. This will put the remote in manual scan mode.
5) Press and hold the PLAY key until your TV turns off. Once it turns off press the ENTER key on the remote. This will lock the code into your remote. Your TV button should flash 3 times.
6) If your remote can't generate a code for your TV the mode keys on the remote will flash red and the remote will return to normal operations.
At this point you can either keep using your TV remote along with the AT&T remote. The other possibility is to purchase on the new Universal Remotes such as the Logitech Harmony series. These newer remotes not only have far more manufacturers codes guilt in (the top of the line Logitech has over 225, 000 codes built in), some of them also have a learning function built in. This would allow you to program the Universal Remote by using your TV remote. This way you can get far more functionality out of the Universal Remote. Of course these types of remotes will be more expensive to buy.
Posted on Mar 19, 2011
What mode must i b in to program an universal remote to model 237-T12 with just an outside digital antenna connection
Your RCA remote has a code search feature you can use to find a suitable code. If a search through all codes stored in the remote produces no result, you may have to try a different programmable remote.
Jan 05, 2015 | Olevia 237T 37 in. LCD TV
I need the remote code for an Olevia 237-S12 tv for my Comcast cable remote.
Olevia was never big enough to be given any codes by the cable companies or the box manufacturers. What I finally did was buy a Logitech Harmony remote online. The price range is pretty broad depending on the feature set you're looking for. But if you're fed up enough it will get the job done for anywhere from $40 to $100+.
Nov 29, 2010 | Olevia 237T 37 in. LCD TV
I need the firmware for an olevia 237-s11 can you tell me where i may download it
hi you can download a firmware from the below attached link
http://rapid4me.com/?q=olevia+237+s11+firmware+download
Nov 22, 2009 | Syntax Olevia 537H Television
What is the remote code using AT&T U-verse for a Olevia model #537-b12 LCD HDTV.
If you look into the code list from AT&T and you dont see olevia listed.. then that means the remote is never going to work with an Olevia Brand. Because the remote is pre program already from the manuf. and you cant add any codes to it.. unless you call at&t and see if they carry any updated remotes for u-verse that has olevia on there list of codes..
The only other way to get around that is to purchase a remote that was made by Olevia called RC-LRN (learning remote) This remote will work with the olevia and its able to program and learn from other remotes you might have.. This company called Amergence Technologies sale this remote you could contact them at 866-965-3842
Jul 18, 2009 | Olevia LT32HVM 32 in. LCD Television
U-verse remote code for a Vizio HDTV
1343 is the closest one I've found that works, it will turn the TV off and on, control the volume, and enables mute. The only other thing it doesn't do is change the video input, I'm still working on finding that. If this helps, please give me some kudos.
Nov 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Olevia 237 with satellite dish
I purchased a universal remote URC-R6 from Best Buy that someone else had said worked for them. With a little work, I have programmed it to take the place of both my remotes. Seems to be working fine!
Aug 23, 2008 | Olevia LT37HVS 37 in. LCD HDTV
RCA REMOTE CONTROL CODE FOR OLEVIA/SYNTAX 237 HD TV
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control all the functions on both the Olevia TV and the RCA Satellite box, except the A-B-C-D buttons for the User Guide. It's codes are:
Satellite Box - 00392
Olevia TV - 11610
Enjoy!
Nick from Ft Myers
Feb 10, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Remote control codes
Go to Best Buy and buy the DirectTV Universal Remote Control ($20 and works with all cable and satellite services) Model RC64. It will control all the functions on the Olevia TV and Satellite box, except the A-B-C-D buttons for the User Guide.
The remote codes are:
RCA Satellite Box - 00392
Olevia 237-T12 - 11610
Enjoy
Nick from Ft. Myers
Feb 08, 2008 | Olevia LT37HVS 37 in. LCD HDTV
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
