Question about Ovens
I have a dacor double wall mont convection oven. 1993 model. I need to replace the saftey thermo switch, ( breaker mounted in the air vent at the top of the ovenes.) The modle number CPS230BC does seem to exit in any search engine, I also have the part number ( there are three on the part) where can i get this part????
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
reg501
  • 413 Answers
SOURCE: F1 error Dacor Oven
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
Posted on Jul 02, 2008
SOURCE: Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Posted on Nov 20, 2008
kachbibi1
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
  • 523 Answers
SOURCE: ECS227 Epicure Electric Double Oven: I have a Dacor model # CPD227R double convection o...
replace touch pad
Posted on May 06, 2010
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
I have a KEBI17DBL8 Oven that will not work after using the self clean cycle. Should I get the thermostat replaced or but a new oven?
No, no need to get a thermostat or replace the unit...yet.
sounds like a tripped hi-limit thermo.
that model number looks like a double oven wall unit, correct ? if so, big job. if not awesome. if it is, it's hard only because these are heavy. (alot of techs like myself have "wall oven carts" that allow me to remove it fairly easy) you might not have to pull it out though if it's not a wall oven, my bad.
however, I think it may be the older unit's manufactured by "Dacor". if so the limit switch on most of those ranges is a "non-resetable" style. meaning you'll have to replace the themal cut-out or aka thermal switch.
*FIRST, unplug the unit or shut off the breaker.
the hi-limit is located by the latch/lock assembly, so you'll need to dismantle the unit to a degree. if it's a free standing range, it's pretty easy. lift the top and the latch/lock access panel is located right there.
you'll need to determine the "why" as well of course. did the cooling fan/blower fail (#4173004), or the cooling fan therostat (#4173008) ?
the part number you'll need for the thermal switch failure replacement is #814505. check the old one by ohming it out first of course.
hope that helps,
good luck
Sep 26, 2009 | KitchenAid Ovens
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
What size is the bottom element in a dacor model w305wc wall convection oven
I'm sure what you are asking. If you need an element, you can order it by your model number, which you have provided. We supply parts and you are welcome to call us at 9728590929 and we will be happy to assist you with your parts orders. We hope this helps!
Aug 14, 2009 | Dacor Epicure 30" Double Wall Oven,...
Dacor Double Oven
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Sep 22, 2008 | Dacor ECS230 Epicure Electric Double Oven
Jen air double oven
Convection ovens shouldn't be dripping anything. If you are making moisture-laden foods and the vent on the unit is clogged...even partly, you may have an issue. Inspect and clean. Pull the breaker!
Nov 20, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
50 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
