Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
The brightness setting is at maximum brightness and the screen is still too dark
    Sergeant:
  • 162 Answers
Your bulb is probably going out and need to be replaced.
Posted on Mar 19, 2011
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
Dark screen when switched on
Try to adjust the screen brightness using your keyboard. If the brightness is at maximum, then you need to replace your screen because its backlight is dying.
Feb 14, 2014 | Packard Bell Computers & Internet
Whenever my Dell Precision M6300 is ever on maximum brightness, the backlight goes dark after 1-2 seconds. The screen is fully functional, but the backlight simply isn't working. I can get the backlight to...
guess there is an larger issue with your notebook.....
you need to get the backlite changed, if you have chanaged the lite then there is a compatibility issue with the screen and the invertor board that's behind the LCD screen.
or the system is not supplying the correct current to the backlite / invertor board
a HW tech guy may solve your issue
Nov 18, 2010 | Dell Precision M6300 Mobile Notebook
Itouchs brightness is really low but the brightness level high
You tried setting the Brightness to maximum, but the screen remained dark? Could be a problem with the LEDs that light up the screen. Also try turning it off and back on.
Aug 08, 2009 | Apple iPod touch
Dark screen
Call the tech support for your computer. The backplane lamps and or the backplane power supply are defective. You will have to have the computer serviced to get the screen lit again.
Jerry G.
Jul 07, 2008 | Polaroid PDM-0855C
Display
Can u see bright screen when ur Ac adpator is pluged in.
if u can,
then,
change the battery setting in the power management options.
set use maximum battery option.
Jan 04, 2008 | Acer TravelMate 2451WLMi Notebook
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Backlight Issue
Sounds like a hardware problem.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
