IS IT 1080i OR 1080p - Televison & Video
    Sergeant:
  • 162 Answers
If it's a new tv it's most likely 1080p.
Posted on Mar 19, 2011
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
Can't get my movies to play in 1080i
Most high-definition movie recordings are in 1080p format. Your video player would have to send the video as 1080i before the TV will play it if the TV is set to 1080i. (Theoretically, 1080i would do better on high-speed action, but 1080p is less prone to odd visual effects such as Moire banding, so that is usually the preferred format, especially given the improvements in video processing speed over the last decade.)
Nov 25, 2011 | Vizio Televison & Video
Can 1080i be changed to 1080p?
The device you connected to your television determines whether or not you get 1080i or 1080p. The television automatically shows the programming in 1080i or 1080p depending upon what the connected equipment is set to. There is no way to change this on the television itself. Currently the only way to get 1080p is with a bluray player or bluray on demand programming from the cable/satellite companies. HD on cable and satellite is 1080i for now.
Nov 04, 2010 | Vizio Televison & Video
WHAT IS THE DIFFERENCE BETWEEN 1080I AND 1080P AND WHICH ONE IS BETTER?
1080i vs 1080p - Similarities and Differences Between 1080i and 1080p
How 1080i and 1080p Are Both The Same and Different
1080i and 1080p are both High Definition display formats for HDTVs. 1080i and 1080p signals actually contain the same information. Both 1080i and 1080p represent a 1920x1080 pixel resolution (1,920 pixels across the screen by 1,080 pixels down the screen). The difference between 1080i and 1080p is in the way the signal is sent from a source component or displayed on an HDTV screen. In 1080i each frame of video is sent or displayed in alternative fields. The fields in 1080i are composed of 540 rows of pixels or lines of pixels running from the top to the bottom of the screen, with the odd fields displayed first and the even fields displayed second. Together, both fields create a full frame, made up of all 1,080 pixel rows or lines, every 30th of a second.
In 1080p, each frame of video is sent or displayed progressively. This means that both the odd and even fields (all 1,080 pixel rows or pixel lines) that make up the full frame are displayed together. This results in a smoother looking image, with less motion artifacts and jagged edges.
Differences Within 1080p 1080p can also be displayed (Depending on the video processing used) as a 1080p/60 (Most common), 1080p/30, or in 1080p/24 formats. 1080p/60 is essentially the same frame repeated twice every 30th of a second. (Enhanced video frame rate.) 1080p/30 is the same frame displayed once every 30th of a second. (Standard live or recorded video frame rate.) 1080p/24 is the same frame displayed every 24th of a second (Standard motion picture film frame rate.)
For more detalis visit http://hometheater.about.com/od/televisionbasics/qt/1080ivs1080p.htm
Oct 09, 2010 | Vizio VP322 32 in. Plasma TV
Is it a 1080 for hdtv
1080i or 1080p are both HD. the i and the p stand for the way the images are displayed. 1080i is interlaced, and 1080p is progressive scan. 1080p is the best hands down for fast moving sports and things like that, but for just watching your basic night time lineup, 1080i is fine.
Apr 25, 2010 | RCA HD52W59 HDTV Projection Television
1080i on tv and not 1080p
No. Most broadcasts are limited to 1080i. BlueRay discs and (now defunct HDDVD) are the only time you will see 1080p. I heard DirectTV may also be running 1080p soon (or already have the option). In any case, 1080p requires 2x the bandwith vs. 1080i. I assure you that unless you see them side-by-side, you will not notice the difference. You many not notice the difference when you do see them side-by-side. The broadcast controls the 1080i vs. 1080p (not a setting on your TV).
Nov 17, 2009 | Cars & Trucks
My tv is Samsung TOCa750. How do I set it up for 1080p and 120Hz?
Resolution such as 1080p,1080i etc. set by your source of the signal, for example, if your cable box set to 720p that is what you going to get from the TV. Cable box is ont capable of resolution more then 1080i because there is nobody broadcast in 1080p yet. Only way you can get 1080p is BD player, upconverting dvd player or media player. 120 Hz is just a frame rate convertor - takes stendard 60Hz and doubles number of frames to 120. So, you will see 120 frames per second instead of 60.
Oct 29, 2009 | Televison & Video
Samsung sold the LNS4695DX/X as a 1080P TV it only 1080i
Nothing broadcast in 1080p....nothing. You probably just need to set your blu-ray player to output 1080p most will default to low resolution. A 1080i max TV is very rare these days.
Jun 10, 2009 | Televison & Video
Just bought, everything coming in at 1080i not 1080p
the xbox 360 does not brodcast at 1080p and no tv channals are in 1080p yet. Blu-ray and HDDVD is the only thing in 1080p yet
Jul 23, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
