Question about Vacuums
I have a Palm Springs Ice Maker Model JS-ZBJ-10, and the Power Indicator Light blinks and tray does not fill up. I have had the water line clogged at one time and blew out the clogged line, but this is not the problem this time as I cleaned it and the light still blinks.
2 Suggested Answers
SOURCE: user manual for Palm Springs
I will advice you check manualnguide.com to search for the manual of your device as requested.
Take care.
Posted on Aug 25, 2010
Why is the indicator light blinking?
Hello! If the charger is plugged in for 12-14 hours or longer the indicator light may begin to blink. Try unplugging if for a few minutes.
Sep 06, 2014 | Dirt Devil M0896RED Quick Power Cordless...
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
My portable ice maker quit working. The water is not getting to the top ice maker part. The model # MCM30SST. The motor sounds like it is working.
If you have recently moved the fridge, you may have rolled the fridge on top of the water line. This would restrict the water flow to the regulator. If the water line is not pinched, then the regulator is bad. You can replace it for around $25 with a universal part, or pay $50 for the original.
Thank,
Jim
Aug 03, 2011 | Vacuums
The ice tray is freezing up . what can be done to fix this problem. I have a magic chef ice maker MCIM30SST
This answer came straight from the manufacture:
Stop the ice maker, and restart when the ice blocks melt. Select the
small ice size. Also Change the water in the reservoir.
Use water between 45 -90 F.
Not sure if that will do it but that is the only fix we could find straight from the manufacture. We wish you the best.
Mar 06, 2011 | Vacuums
I DON'T HAVE INSTRUCTIONS FOR A TM4 MR. COFFEE ICE TEA MAKER I BOUGHT AT A THRIFT STORE TODAY. I DO NOT KNOW HOW IT WORKS. I PRESS THE BUTTON AFTER ADDING WATER TO THE WATER LINE BUT IT CLICKS OFF...
I just got the exact IcedTea maker that you have (model TM4) from Mr. Coffee. I think that we were both trying to make it work the same way, which is wrong. The plastic pitcher goes on the bottom, while the part that plugs in with the button&indicator light goes on the top. Put water in the pitcher to the indicated water line and then pour it into the part with the metal basket. I didn't have any directional sheet either so I didn't know that the water goes in there. I thought the water would be gently warmed while in the plastic pitcher. After pouring water into the heating part, fill the pitcher with ice to indicated level (about 2 ice cube trays). Place the heating part with the button&indicator light on top of the plastic pitcher and cover it with the white lid. Push the button and it will heat the water and dispense the brewed tea into the pitcher thru a valve. The indicator light will go off when the brewing process is done. The entire manual can be downloaded from going to: http://www.mrcoffee.com/manuals/MrCoffee/tm4.pdf I hope this helps you if you still have the item. I bought mine to give my daughter while in college. I really like that it is so space saving compared to many that I am finding in stores today. Good luck and happy brewing!!! Susan
Mar 05, 2011 | Vacuums
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
Cleaning mr coffee ecm3 how
Deliming
SUGGESTED CLEANING SCHEDULE
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
I am looking for a specific part for a Nostalgia Electrics RIC-100 portable ice maker and I am finding it very hard to find what I am looking for if I could get some help that would be great. The part I...
Try to google for it but if unsuccessful you may have to resort to some sort of repair that will do the trick. May not look great but if it works, then.............................
Aug 24, 2017 | Vacuums
Vacuums Logo
190 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
