Question about Epson Artisan 800 All-In-One InkJet Printer
I have a artisan 810. it is taking several minutes or longer from time you hit print until it actually prints. sometimes doesn't even work.
    Sergeant:
  • 162 Answers
You can try and change the cable between your computer and the printer to make sure if that it the problem. Other option is try and reinstall the driver again.
Posted on Mar 19, 2011
Epson artisan 810 prints vertical black lines on all documents
this problem is usually fixed easily. this commonly occurs when print head is clogged. I use a facial tissue and alcohol to clean the head with the ink cartridge in an upside down position (if possible) then i print one or two test prints to get it back to normal.
Jul 06, 2014 | Epson Artisan 800 All-In-One InkJet...
Using continuous ink system with no problems, but the black print head will no longer improve after cleaning. Can it be replaced?
It's too expensive for replacing the head. Better buying new printer. Btw, try cleaning print head using manual procedure. Just browse here. It post many times.
Jan 21, 2013 | Epson Artisan 810 AllInOne InkJet Printer
Artisan 810 will not print black
i have same model need to clean head of catridge then used air spray to clean heads of printer then install back again if this don't work then need to get new cartridge
Oct 13, 2012 | Epson Artisan 810 AllInOne InkJet Printer
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
My Artisan 810 ADF gets jam error. There is no paper there. The motor just whirls and then gives ADF jam error. My 810 is near new, less than 300 sheets printed, less than 100 scanned using...
Just fixed my problem today. It was the ADF assembly motor. The spur gear had cracked open where it can no longer grip tightly to the center rod when the motor spins. I bought a new motor assembly from CompassMicro for the total amount of $23 and my printer is back in running order like normal again. Beats taking it to a repair center and get ripped!
Sep 10, 2010 | Epson Artisan 800 All-In-One InkJet...
I have an Epson Artisan 810 printer. All of a sudden, the printer will not print the black color. I just changed that cartridge and that didn't help either. Thanks!
Hi you should clean the print head and you need to take out the cartridge and pay close attention as you put it back into the printer because it may not be fitted in place properly.
Aug 08, 2010 | Epson Artisan 800 All-In-One InkJet...
Where/how do you load a CD for printing directly onto CD?
There is a special tray that you are able to slide out when you open the front. Take a look at this picture: http://www.blogcdn.com/www.gadling.com/media/2009/11/img_0204-[gadling-bumper].jpg
May 29, 2010 | Epson Artisan 800 All-In-One InkJet...
Cannot print on wireless printer
..goto setting and disable the wireless setting on your printer.. then you should be able to print..
May 22, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson artisan 800 wont print to a transparency
OK so i tricked my 810 into printing on a transparency. NOT that I recommend doing this ... but .... I took four pieces of clear tape and taped the top (where it goes into the printer) and on each side about three inches from the top.
Then I put it in the tray with the transparency on the bottom of the paper -- since it brings it up thru the printer and flips it over, it prints right onto the transparency !!!
It didn't like it the first time, since I just folded over the tape on the end that gets sucked into the printer first. Hence the added stabilizers on each side.
Feb 15, 2009 | Office Equipment & Supplies
Printer hangs and prints slow
Dell replaced it for a 928 printer which is fine. Apparently the 810 won't work with vista
Oct 23, 2007 | Dell 810 All-In-One InkJet Printer
Epson Artisan 800 All-In-One InkJet Printer Logo
180 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
