Question about Rowenta Commercial Garment Steamer - White
Dear sir or madam, I am writing to you on behalf of a customer, i am based in a domestic appliance shop called 'Vac Attack'. Although we mainly focus on vacumm cleaners, we had a customer bring in a Domotec DSC00009 Steamer. Now we tried to contact the manufacturer, but it seems they have gone out of business, so there is no way of tracking them down. The problem we are having is that the machine is creating steam but the steam isnt coming out of the hose, the tank is heating up so steam is being created, and there is more than enough pressure. All of the electricals from the hose to the machine are fine so we know its not an electrical failure, also all of the other wires have been checked, just to be sure. The steam must be escaping somehow but we are just getting small spurts of water now and then, even when we change the pressure, and to be honest we dont want to go any further with the machine as we dont know what we are doing, is there way you can help? Kind Regards Lee, Vac Attack
I had a similar problem a couple of weeks ago.
I found that there was scale blocking the inlet to the rotary steam control valve.
A poke with a coctail stick and a bit of air cleared it.
Posted on Jul 29, 2011
  • 757 Answers
It sounds like the problem is related to the impeller. Vaporizing water, even if it has been distilled, will eventually leave behind it's minerals and deposit it where ever the vapor is allowed to dry. I think if you disassemble the unit and clean it, then lubricate the rotating parts with a silicone based gel then it should likely operate.
Posted on Mar 19, 2011
I have a Russell Hobbs easyfill 2400W Iron. Water is running out the base of the iron. How can this be rectified?
take it in to an appliance repair shop
generally it is cheaper to junk it and get a better quality unit
Dec 21, 2017 | Russell Hobbs Irons
My babyliss pro tt straightener hit the floor now it will not turn on
We live in a disposable society. In the old days, you could take small appliances to a repair shop and have them serviced. Today there are too many different devices from too many sources to adequately maintain and stock parts for any kind of repair shop. Also, most devices are so mass-produced that they would cost more to repair (labor cost) than the device is worth. unless the damage is obvious and can be repaired easily, you are best to just write it off and buy another.
Jul 14, 2016 | BaByliss Pro TT Tourmaline Flat Iron /...
My Iron keeps tripping the fuse in main power box what is causing this it doesn't happen with any other appliances?
Tripping the breaker or fuse as you call it is caused by excessive current draw. These are safety devices that are meant to protect from electrical overloads and fires. More than likely your iron has a failing heating element and should be replaced. If it is a steam iron it is also possible that it has developed an internal water leak causing a short. Continued use is unwise and a potential safety hazard.
Feb 19, 2015 | Irons
TEFAL STEAM GENERATOR GV8460 NO STEAM IRON HEATS UP
The water is heated by a metal plate that is bolted to the metal water tank, operating in pretty much the same way as a domestic kettle, the plate being the element. The plate is fixed in place by 8 or so nuts onto studs that form part of the water tank and heated by passing electrical current into this plate. Over time the nuts come loose and consequently the plate is not in full contact with the water tank. This results in insufficient heat transfer and a failure to consistently reach the required temperature to create steam. Ultimately you will need to remove the plastic base of the unit to access the plate and re-tighten the nuts. You will need a small 6 star bit with the centre punched out to remove the base as it is secured with security screws. These are readily available on ebay as they are the same as those used to secure number plates.
Apr 27, 2012 | Tefal Pro Express GV 8120 Iron
Not heating what will be the problem
if it is not heating up -- the problem could be a few things,, it could be a bad cord / connection ( at the iron side or at the plug side ),, it could be a bad switch ,, or it could be a burned out heating element. if you have a volt meter ( or know someone that does ) - you can do a few test to the wiring and see what the trouble is.
if you need further help -- please feel free to write me back here and I will walk you through the steps the best way that I can. but if you do not have a volt meter - then just drop it off at your local small appliance repair shop and for a small price I am sure they can fix it quickly -- if it is just a loose wire or bad plug - the cost will be about 10 to 15 dollars ( depending on where you live ).
c...
Feb 23, 2011 | Panasonic NIA56NR NI-A56NR Iron
I have a black & Decker digital advantage iron. it is about a year old and when I plug it in it beeps and comes up with err or. Can you tell me what is wrong or what i can do
Hi!
I really hope someone can come up with an answer to your problem.
Personally, I have an iron, and a toaster, and a toaster oven with the old-fashioned dial where the degrees of heat are approximately displayed.
I had them for decades it seems, and I've never had to suffer any fallout from either ironing my shirts at plus or minus 5 degrees from the digitally recommended temperatures, nor from toast that was slightly darker one day and lighter the next.
I'm not a caveman, just in case you wonder. I do have a microwave oven with a dial timer as the only variable, and I must say on its behalf that it has served me without a hiccup the dozen times I used it to either warm my tea, or help defrost the odd TV dinner, which ended being cooked in the toaster oven.
In all seriousness however, needlessly digitally controlled appliances just because it's cheaper to manufacture them, don't score highly with me.
Furthermore, these electronic circuits appear to have a predetermined and highly predictable life expectancy, and oftentimes the appliances they control are cheaper to replace than to repair.
Feb 14, 2011 | Black & Decker Irons
Steam comes out of the base system reducing the amount of steam that now comes out of the iron. The filter has been changed, could it be block with scale.
Yes it could. Try using CLR, Lime Away, both are Calcium, Lime, and Rust removers. They attack and disolve all 3 types of build ups almost instantly. You can buy eithere at most supermarkets, hardware stores. Use it on your shower heads too, it will improve water flow, Follow instructions to the letter,
May 16, 2010 | Morphy Richards Jet Stream 42271 Iron
Rowenta iron will heat up and then shut down. Have to keep plugging and unplugging the iron.
Irons use a potentiometer and thermister to control the heat on the element. One of these components is bad and needs replacing. If the iron's still under warranty, get another one. The cost of service would probably be as much as a new iron, but you could call an appliance repair shop to check.
Mar 12, 2010 | Rowenta Professional DM890 Iron with Auto...
Re: Where to purchase cap on generator resevoir
I HAVE DG050 BUT STEAMER NOT HEAT HEAT ENOUGH TO STEAM THE WATER
Aug 15, 2008 | Irons
Rowenta Commercial Garment Steamer - White Logo
532 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
