Question about Microwave Ovens
I have a fridge equipped for an ECKMF90. That is what the cover states in the freezer. I have a different icemaker and dont know what the model is. It will fit fine. What I need to know is this: the rectangle plug in the freezer has two white wires in one, a black wire a brown wire and two greens in one in that order. The ice maker i have had a round plug and I cut it off and have a white wire, a brown wire a orange wire and a green wire. Does the orange wire and the black wire go together, since the white has a white the green has a green and the brown has a brown to match to.
  • stephen bruno
    stephen bruno Mar 19, 2011
    Kenmore ice maker and the white plastic end cap has a wiring diagram inside it showing the orange wire going to the hold switch and then to the feeler arm switch, the brown wire going to a relay or junction or splitter where it goes in two directions one to the motor and one to a mold heater , the white wire going to the water switch and the green going to a ground i believe it is. Kenmore ice maker with a white, a brown,a green and a orange wire that were in a 4 pin round plug. i cut them out to put in a 4 pin flat plug in a whirlpool fridge model BT14UKXNA00 that has a green , a brown , a black and a white wire. Does the green connect to the green, the white connect to the white and the brown connect to the brown leaving the black and orange to connect? I cant afford a new ice maker or a kit with the round to flat plug adapter so any help would be great. THANK YOU Stephen
  • stephen bruno
    stephen bruno Mar 22, 2011
    I dont want to plug the fridge into nan outlet I want to wire the ice maker
    Genius:
  • 1,622 Answers
Hi,For residential wiring, some basic rules given in the NEC are:
* Phase wire in a circuit may be black, red, orange (high leg delta) insulated wire, sometimes other colors, but never green, gray, or white (whether these are solid colors or stripes). Specific exceptions apply, such as a cable running to a switch and back (known as a traveler) where the white wire will be the hot wire feeding that switch. Another is for a cable used to feed an outlet for 250VAC 15 or 20 amp appliances that do not need a neutral, there the white is hot (but should be identified as being hot, usually with black tape inside junction boxes).
* The neutral wire is identified by gray or white insulated wire, perhaps with stripes.
* Grounding wire of circuit may be bare or identified insulated wire of green or having green stripes. Note that all metallic systems in a building are to be bonded to the building grounding system, such as water, natural gas, HVAC piping, and others.
* Larger wires are furnished only in black; these may be properly identified with suitable paint or tape.
* All wiring in a circuit except for the leads that are part of a device or fixture must be the same gauge. Note that different size wires may be used in the same raceway so long as they are all insulated for the maximum voltage of any of these circuits.
* The Code gives rules for calculating circuit loading.
* Ground-fault circuit interrupter (GFCI) protection is required on receptacles in wet locations. This includes all small appliance circuits in a kitchen, receptacles in a crawl space, basements, bathrooms and a receptacle for the laundry room, as well as outdoor circuits within easy reach of the ground. However, they are not required for refrigerators because unattended disconnection could cause spoilage of food, nor for garbage disposals. Instead, for refrigerators and other semi-permanent appliances in basements and wet areas, use a one-outlet non-GFCI dedicated receptacle. Two-wire outlets having no grounding conductor may be protected by an upstream gfci and must be labelled "no grounding". Most GFCI receptacles allow the connection and have GFCI protection for down-stream connected receptacles. Receptacles protected in this manner should be labeled "GFCI protected".
* Most circuits have the metallic components interconnected with a grounding wire connected to the third, round prong of a plug, and to metal boxes and appliance chassis.
Hope it helps..If you don't understand what i wrote,i would advice you to contact an electrician for help..Thanks you..
Posted on Mar 19, 2011
    President:
  • 2,047 Answers
Usually the fact that the wires have the same color does not mean that they are meant to go together. But in your situation since the other colors match then they are menat to go together. Although according to color coding the black is meant to be neutral while orange also stands for neutral.so both wires could go together. But in rare cases the wires coding could have been mixed up so best get an expert to examine it and test the cables to determine which is which to avoid unforeseen damage.
Hope this solution has been helpful?
My freezer is draining water into the refridgerator. how do I fix this. The back of the entire unit is covered.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 24, 2011 | Microwave Ovens
Hi, I have a amana fridge with freezer on the bottom. It has an ice maker and water dispenser. The big problem is a buzzing noise comming from the fridge, it start aprox every 16 min and buzzes for 10...
The buzzing you hear is the water valve trying to run water to the icemaker. If there is no water going to the icemaker it will be going into cycles one after another. And when it does it adds heat into the freezer. Turn the ice maker off and see if the freezer gets colder.
May 20, 2011 | Microwave Ovens
I hope someone can help me. I have a Whirlpool Fridge Model Number WRN52HWG6 and we bought it from Fridge and Freezer City O'Connor Perth about 6 months ago and I don't have the owners manual for it...
If you turn the dial clockwise this will make it colder anticlock less cooler...Start by switching off for a few Hours leave door open to allow defrost...Turn the stat fully anticlockwise to almost off then put it to say 2 o clock position assumming that it will go from 12 to 10,this should allow food to remain cold without freezing.you are looking for about 3/8 Degrees c.....Buy a cheap thermometer this will help to keep you on the right track..Good luck
Mar 07, 2011 | Whirlpool Microwave Ovens
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
I hav 2 buttons that hav signs on it at the top of my freezer i dont know what theyre for...if i push 1 of the buttons it lights up so i dont know if they should be on or off cause i dont know what theyr...
An orange button with a snowflake on it normally means 'fast freeze' and should only be used (lit up) if you have added a large item to the freezer and want it to freeze quickly. I assume the button marked 'super' means 'super fast freeze' but without knowing the make and model of your freezer it's difficult to be certain. If you can provide those details I will respond again.
Jan 04, 2011 | Microwave Ovens
I have a Teka A-FCI340 fridge/freezer. The fridge is too cold and freezes items put into it. No matter how I turn the temperature control dial it still seems to be too cold.
I had the exact same problem with the same model and mine was just 3 years old. My problems started when I defrosted the freezer. I spent 75gbp on an engineer who told me that I had probably 'spooked' the fridge when I defrosted the freezer, that this particular model of fridge wasn't designed to last longer than 2 years.
I would recommend you check the door is shutting properly (check the screws at the top, it might be just slightly out of alignment).... I turned the whole unit off for over 2 days to allow absolutely everything to defrost (both inside and on the back of it)... within 30 minutes of turning it on, the back of my fridge was already frosted over.
Engineer told me not to waste money calling them out again, and to buy another one...
Oct 17, 2010 | Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Refrigertor not gettng cold enough, and now freezer is doing the same. when we turn the number to 9 you can hear it go on - but still food is defrosting. Milk in frig not getting cold enough. Refrig is...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
