Question about Hayward S220t Top Mount Pro Series Sand Filter 22" Tank Include Top Mount Valve
The round position guide is gone & I need another one.
  • 56 Answers
If it is under warranty you can contact the manufacture at: http://www.haywardnet.com/forms/contactForm.cfm and request the part according to their part listing https://www.hayward-pool.com/pdf/Parts%20Diagrams/ProSeries-Top-Mount.pdf
If it is out of warranty you can use the same part listing to order a replacement from your preferred pool supply vendor.
Posted on Mar 19, 2011
How do I remove expansive cap holding screw so I can replace broken toilet seat?
Porcher 70018 Bathroom Toilet Seat Round Front ... - Fixya
www.fixya.com/support/...porcher_70018_bathroom_toilet_seat.../popul...
Popular Porcher 70018 Bathroom Toilet Seat Round Front White questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair tips ...
Aug 25, 2015 | Porcher 70018 Bathroom Toilet Seat Round...
Tip
Washer knob / Dial going round & round
If the washer knob of the unit is going round and round all by itself it means that there is something that has malfunctioned in the unit or else there was an error in setting proper cycles.
You will first need to reset the unit, to see the reset procedure click here
Once you have reseted the unit and even then the washer knob is going round & round it means that a part or parts in the machine have gone bad which may need to be replaced.
The question would be how can one understand which part in the unit has gone bad.
To make things easier, here is what needs to be done to know which part has gone bad.
  1. After reseting the unit, set a new cycle and switch on the machine.
  2. If the washer knob starts going round and round, the mode+Door lock light will flicker in a sequence, for example, it may flicker 4 times before taking a pause and then flicker 4 times again and continue this sequence.
  3. Once you know what is the count which is also the fault code there is a fault code chart which you can refer to understand which part has gone bad.
  4. The fault code chart is as follows:
Hope this helps, do let me know if this information was helpful or else you need more clarification on the same.
on Mar 02, 2010 | Washing Machines
Plastic bobbin gear rod unscrewed, how to align with bobbin round gear
Type into browser: http://fixsewingmachine.com for diagram and instructions. Hope this helps! Jimmy
Apr 06, 2012 | Brother LS-2125 Mechanical Sewing Machine
I have a saniplus in a bathroom with a sink & shower. It isn't used often. The water backs up in the shower. The toilet won't flush, only hums. Any suggestions?
If the pump is humming and backing up then there is a blockage on the drain pipe, blades or the impeller. Also the capacitor may have gone bad and it will need to be replaced. The capacitor drives the blade and impeller, if it goes bad then it would just hum and not pump out the waste.
Oct 26, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My cd room couldn't read any more cd's :S:S what can i do ?
Either your CD/DVD drive is dirty & needs to be cleaned, or the drive has gone bad & needs to be replaced.
First, try to take the drive off the laptop. Open the drive & blow compressed air into it (from a can of compressed air) to clean it. You could also clean the lens (the small round glassy object inside the drive) using lens cleaning tissues & lens cleaning fluid.
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD drive
Sep 07, 2010 | Toshiba Satellite L305D-S5881 Notebook
Cd/dvd rom will not work
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD drive.
Sep 06, 2010 | Lenovo IdeaPad Y510 Notebook
My advent cd drive stopped working what could it stop working
Aug 29, 2010 | Computers & Internet
Cd rom donot work
Aug 27, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Cd drive doesn't read disks
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD driv.
Aug 22, 2010 | Dell Inspiron 2200 Notebook
Hayward S220t Top Mount Pro Series Sand Filter 22" Tank Include Top Mount Valve Logo
298 people viewed this question
Top Hayward Garden Experts
Craig Butler
Craig Butler
Bill Boyd
Pushkar Singh
Pushkar Singh
Are you a Hayward Garden Expert? Answer questions, earn points and help others
