Question about HP Compaq nc6120 Notebook
I have a compaq nc6120 laptop. The power cord where you plug it into the computer has a small hole that goes around a pin. That pin broke off the computer and is in the power cord. I can easily pull it out of the power cord, but don't know what is recomended from that point. Do I need to replace that part, or can you solder the thing together completely. I don't need to transport this laptop, so if it were permanently connected I would't care. Looking for suggestions?
    Sergeant:
  • 162 Answers
To be safe i would definitely buy a new ac adapter. go to ebay and just buy a generic replacement so you don't have to spend a lot of money.
Posted on Mar 19, 2011
    Sergeant:
    Champion:
  • 236 Answers
You will need to have this resoldered on the motherboard itself
The adapter light is on when first plugged in but then when I connect the adapter to my laptop the light goes off and it doesnt supply any power
I suggest check out the AC adapter first.
1) When plugged into power, and plugged into the laptop, gently wiggle the cable from the AC adapter TO laptop.
Any change?
Do the same on the power cord TO AC adapter.
NO?
Go on.
2) The port on the laptop that the plug from the AC adapter plugs into, is the DC Power Jack.
If we are discussing an Acer Aspire 5738Z Notebook PC, the DC Power Jack resembles this one, (Not installed),
http://www.batterysupport.com/acer-aspire-5738-jack-p-302046.html
(When I note the DC Power Jack, it is this link I will be referring to )
As you can see there is a Center Pin. All power removed from the laptop, use a small wooden, or plastic object, and see if this pin moves around.
ANY perceptible movement means a bad DC Power Jack.
DC Power Jack checks out it's back to the AC adapter.
Wanted to perform the easy diagnosis first.
This will require a multimeter. An economical, yet fine for this test multimeter, can be purchased for as little as $8 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Analog or digital is fine.
http://www.youtube.com/watch?v=bF3OyQ3HwfU
(Analog is fine. Some of us still like 'em)
DC Voltage is what you are going to check.
Black probe lead (Negative) goes in the Common port on the multimeter. (COM)
Red probe lead (Positive) goes in the Voltage port on the multimeter. (V)
If the multimeter just has symbols around the Function Knob, set it to the dotted line over a solid line, symbol.
The plug on the end of the AC adapter, that plugs into the laptop, has a center hole, and a cylindrical metal shield surrounding it.
The Center Hole of the plug is where the red Positive lead, of the multimeter goes.
The outside cylindrical metal shell is where the black Negative lead of the multimeter goes.
Hold the AC adapter plug in one hand, and at the same time hold the red Positive multimeter probe in the center hole.
With the other hand touch the black Negative lead of the multimeter, to the cylindrical metal shield on the outside of the plug.
You should read 19 Volts (DC), or VERY close to it,
http://www.cellularfactory.com/laptop/ACER/3/305268/
I believe the AC adapter is the problem. Post back in a Comment as to your findings.
Regards,
joecoolvette
Apr 29, 2012 | Acer Aspire 5738Z-423G32Mn Notebook
I am unable to charge mt battery on an HP Compaq nx6235. It will not work even with the power cable pluf=gged in. Tried everything but unabke to get any power
You can try hp compaq nc6120 battery as a replacement battery for your HP COMPAQ laptop. The Business Notebook NC6120 battery meet or exceed the original Business Notebook NC6120 notebook/PC batteries. Buy this rechargeable Li-ion HP COMPAQ Business Notebook nc6120 battery pack is cost-effective now.
Sep 14, 2011 | HP Compaq nx6325 Notebook
My hp laplaptop error power surge on hub what do i do?
you'll have to provide more details about the problem. From what little you've said, I suppose your laptop wont turn on both when trying it on battery and on power cord. If this is the case, you may be facing the well known Maxim chip problem. he nc6xxx series are known to have these problems with the Maxim chip and the power plug on the motherboard. You can find the Maxim chip and power plug resolder instructions here.
Nov 22, 2010 | HP Compaq nc6120 Notebook
Battery charger
Yes. Usually they either work or they don't so obviously when they test good they should charge the battery. Dell laptops have a "data pin" that determines what wattage of power cord is plugged. If this data pin goes bad on the power cord or motherboard the laptop won't charge.
May 03, 2010 | Compaq Presario Notebook
I hav a hp nx6120 but doesnt switch and wen you plug in the charger its no lighting
Take a look at the back of the laptop. Is the gold power pin still there or is it now stuck in in the end of the power brick cord?
HP actually extended the wty on these machines because of the
power pin issues. If the power pin is missing you will need to have the machine serviced. Out of wty, replacement power pins are easy to solder on the board if this is the issue.
If your pin is still there... Your AC cord or power brick may be the next things to check. Connecting them to a meter will tell you if there is power. Try moving the cords to check for shorts in the wires.
If your AC cord and brick are good, try pulling the battery. Your laptop can run off AC only. Batteries with bad cells can sometimes prevent the machine from powering up.
If its still not powering up after all of that, there may be an issue with the motherboard in the machine.
Feb 27, 2010 | HP Compaq nc6120 Notebook
Broken power plug in pin on computer
Ebay has a very good selection. Just put your make and model in the search box and away you go.
Sep 17, 2009 | HP Compaq Business nc8230 Notebook
Help! Compaq Laptop "Plugged in,Battery Not Charging"
I had the same problem on my CQ60. HP battery test showed one or more cells not working. After spending about 2 hours talking to some guy in India,or somewhere, he came to the conclusion that my battery was bad. HP sent me a new battery, which fixed the problem.
kenbun
Sep 11, 2009 | Compaq Presario CQ60-220US PC Laptop
The pin in the middle of the power cord input has come out
unfortunately that is an impossible fix...
the only real way to do is complete replacement of internal charging device, which, depending on the laptop, may be cheaper just to go get a new one
Jun 28, 2009 | HP Compaq nx9030 Notebook
The pin that the power cord goes into has broken off
Is the cord broken in the computer, or the monitor or the pin broken and stuck in the machine? If it is in a desktop it goes into the power supply. Which you can change the whole power supply fairly cheap. that is if it in a desk top computer. 4 screws, 4 or 5 connectors and ta da new power supply, All you need is readings off power supply such as wattage. Good luck
Mar 10, 2009 | Acer TravelMate 2480 Notebook
My nc6120 broke?
well known fault caused by faulty motherboard,you can disable your usb ports which will stop the annoying fault reports and you can use your latop as normal but obviously you cannot use your usb ports as you have disabled them
Jul 19, 2008 | HP Compaq nc6120 Notebook
HP Compaq nc6120 Notebook Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
