Question about Samsung MW6350W Microwave Oven
Microwave shot off completely; I check wall plug and it is ok
  • Samsung Master
  • 6,993 Answers
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care...
Posted on Mar 19, 2011
How to remove ge spacemaker xl
You want to take the microwave off the wall, is that correct. 1st unplug the microwave--plug should be in the cabinet over the microwave. Next--in the same cabinet you should see 2 or 3 phillips head screws with big heads going through the bottom of the cabinet into the microwave top. Have someone hold up on the microwave while you remove the screws. They are about 3 inches long. Once the screws are out, the microwave should tilt forward and downward at the front. The back of the MW sits on 4 tabs on the wall mount plate so to get it off completely you have to lift the back up slightly off the tabs about 1 inch. Feed the power cord down through the cabinet and you are done.
Feb 28, 2015 | GE Profile Spacemaker XL 1800 36"...
There is no power going to my microwave. The fuse is ok
Have you tested your plug outlet with another appliance? If not it could be your wall plug.If this OK then contact a technician in the yellow pages.
Feb 16, 2015 | Microwave Ovens
Ss25 microwave no power fuse in plug ok, where is internal fuse.
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave
Oct 04, 2011 | Microwave Ovens
Up/down control of BROAN ELITE / RMDD4804EX/ Downdraff, in a suddent is out of order, the unit keep running up and down by itseft
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset. This should help fix the problem.
Jun 15, 2011 | Microwave Ovens
My Advantium over is approximately 9 years old. I heated up broccoli last night for dinner and then it just went out. There is completely no light on showing the time and I checked the breaker switch. Do...
check the wall socket to make sure you have electricity to the plug. Secondly then check to see of the appliance "fuse" has blown, simple repair. If not, you have a costly serious issue.
Oct 07, 2010 | GE Advantium 120 Convection/Microwave Oven
I was using my microwave for over 10 minutes and before the time was up it completely shut off. No lights or power. Did it overheat? What can i do to fix it?
It may have blown a fuse, the fuses on some of the GE models are behind the control panel.
Try unpluging from the wall and plug it back in to reset the controls. Check your power trip to see if you have power at the plug point.
Jan 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge profile microwave. When I plug in the microwave, it's fine. As soon as I hit the start button, the microwave blows the HVT fuse. I assumed that it was the diode and the capacitor that were bad....
Another possible option would be to cheak the door micro switches . They can also blow the ceranic fuses.also how did you cheak the magnatron?Did you remove it complet and cheak over the ceramic end area if it was bubled?
May 15, 2009 | Microwave Ovens
Samsung MW6350W Microwave Oven Logo
50 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
