Question about Microsoft Xbox 360 Console
I dropped my xbox 360 this morning moving it it was on cause i was waiting to donload somthing now it wont do any thing the power cord case that plugs in to the acutal xbox is broken help
  • 767 Answers
Kinda a tuff one , because if your box hit lower corner of
the console it's possible you could have crack the board,
this is bad . I'm very good at recovering badly damaged
console , Ok first unplug the power from the console
now plug it back in Hard so it connects . Watch the yellow
light on the power brick if it appears to flicker or dims a little
check inside the Two usb ports to see if you didn't break
the inside of the connectors ,if so one or more of the 4 wires
(cotacts) may be touching .If you separate those contacts
your console will come back to life ,provide they are broken.
It's a shot in the dark , with out it being on my bench
It's hard to say for sure.
Check that first before you take it to a repair shop.
Hope that helps
Rob
Posted on Mar 22, 2011
When i turn on my xbox i'm getting 3 flashing red lights what does this mean
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
Jun 13, 2011 | Microsoft Xbox 360 Elite Console - Black
Tip
How to create a Xbox live ID
<ol> <li><br /> <p>With your xbox turned off unplug the ethernet cable from the back of your Xbox.Next unplug the xbox 360 power cord from the back of the Xbox 360.<br /></li> <li> <p>Unplug ethernet cable<br /> <p> and power cord from the modem. Wait for about 1 minute and then plug ethernet cable back into the modem.Now you need to plug other end of the ethernet cable into the back of the Xbox 360.<br /></li> <li> <p>Plug the modem power cord back into your modem , wait for lights to light up on your modem (this can take up to a minute).The last step is to plug the Xbox power cord into the back of the Xbox, turn it on and you are ready to go<br /></li></ol>
on Dec 06, 2010 | Microsoft Xbox 360 Console
How to setup xbox live
Hello there
No problem, in just a few steps you too will be online and ready to go.
Ethernet Cable
With your Xbox 360 turned off unplug the ethernet cable from the back of your Xbox.
Xbox 360 Power Cord
Next unplug the Xbox 360 power cord from the back of the Xbox 360.
Unplug ethernet cable and power cord from the modem. Wait for about 1 minute and then plug ethernet cable back into the modem.
The last step is to plug the Xbox power cord into the back of the Xbox, turn it on and you are ready to go.
Oct 10, 2010 | Microsoft Xbox 360 Console
My 360 does not have power to console. the light
Have you tried removing all extra accessories?
Xbox.com states:
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Mar 01, 2010 | Microsoft Xbox 360 Console
Xbox 360 won't turn on
I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
Oct 09, 2009 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
I have a Yellow Led light on power bar, xbox will not turn on
Here ya go! This should help you out, I have also had this happen to me. Don't worry, its nothing like the red circle of death.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Hope this helps you out! Don't forget to rate me :)
Apr 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 turns on somtimes
open the xbox and fix the faceplate yourself and try getting a new power cord or a new powerbrick
Dec 09, 2008 | Microsoft Xbox 360 Console
Xbox360
Sep 06, 2008 | Microsoft Xbox 360 Console
Xbox 360 video problem
In case it is overheating, you should move the 360 into open space when it is on. Those things can get pretty hot, especially when on for long periods of time.
However, it is more likely that there is a problem with you audio/visual cable (the three pronged thing). Check for any breaks in the cord, or the prongs themselves. The metal pieces can become detached. If this is the problem, buying a new cable is the best option, and wont set you back too much.
There is also a switch at the base of the cable (where it plugs into the xbox) you should make sure it is set to TV and not HD-TV. That could also cause the problem.
Feb 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
147 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
