Question about Cell Phones
It scrolls up and down by its self it only takes one kind of charger even if you find one that fits it want charge after you take it off the "wrong" kind of chrger it shuts off... this morning i went to my call log and it scrolled down up and over then shut off i tried to turn it on the verizon screen pops up and it cuts off everytime i try it i thought putting it on chrge would help but it wouldnt even light up then i plugged my cord (and phone) up to my laptop it cut on for about a minute then cut back on what do i do to get it on and staying on?
    Master:
  • 344 Answers
It sounds as though they might be a short in the battery or the battery was damaged. You should take it to Verizon and have them test it. I believe they will do this free of charge. Your area store might be different though.
Posted on Mar 19, 2011
Charger showing full batteries not
No, you almost for sure have screw down terminals on your battery, not a fitted battery. The charger will read full when the charger has filled it as high as it can or has fully cycled. With a full charge take your batteries to an auto store or mechanic and have them tested.
Apr 20, 2014 | Pride Health & Beauty
Can you charge camera from USB?
You don't say what make or model the camera is, so I can only answer generally. Most cameras, as opposed to most cellphones, do not charge the battery in the camera at all. They are supplied with a separate mains charger- you take the battery out of the camera and put it in the charger. I have a number of cameras with USB connectors, and none of them charge while connected to the computer.
If you bought the camera new, and it came with a charger, then the camera almost certainly needs the charger to charge the battery. If you purchased it used or it was a hand-me-down, and you didn't get a charger, then the seller or giver has probably been remiss. It won't hurt to leave the camera connected to the computer's USB port to see if it will charge, but when that doesn't work, you can find a replacement charger for your camera by searching Amazon with the camera model number and the word "charger". Better, you can get a "universal" charger on Amazon for as little as $4 that will charge any of the small lithium batteries used in cameras and phones (assuming this isn't a huge battery of the kind fitted to older video cameras). I have a universal charger and it is easy to use and has saved me a lot of money as I no longer need to buy a replacement for every type of battery I come across.
Jan 02, 2011 | Vivitar Cameras
Battery isnt charging.
any battery that has been completely flat can often get whats called sulphated plates if this happens the battery may never recharge and if it did take some charge it wont be much good after, the battery has had it realy the only this you could try is a very slow long charge but even this may not work,,,as a last dich try putting an asprin into each sell,,, yes thats right an asprin it dose work some times but for the life of me i dont know why, it just dose! as for whats the best battery,,,its all down to price at the end of the day, if its a cheapy type battery it wont last very long but il give you a good tip,,,,buy your self a 12 volt solar charger of say 2.5 watts a 1.5watt will just about do for a small battery,, when your going to lay the bike up the next time hook up the solar charger to the battery and forget it,,, the solar charger only needs daylight to work but sun light is better, and it will keep the battery toped up all winter i use them on my bikes (BMW 750cc 35amhr battery fitted) put on at the begining of winter took off in spring and they start first time every time,,,free power,,good huh!
Jan 23, 2010 | Honda CB 100 Motorcycles
How to fix or repair a panasonic 12v cordless
it realy depends on what kind of charger it is, if it has a coil or a switch mode charger, switch mode chargers have ic's in them and changing them or even getting them may be very hard, if its a coil type check output on coil as its likley to be that they have a built in thermal cut out fitted witch burns out, if they get over heated,,,
Dec 06, 2009 | Cameras
It's fully charged and had turned its self off, but wont turn it's self on again
connect the iphone to the wall charger. Hold down both the sleep/wake button at the top right and the home button at the same time. Hold both of those buttons down while iphone is connected to the wall charger, hold them down until you see the white apple logo appear. Once you see the logo, let go. It will take a minute or two, but the phone should be powered on and back to normal. Leave plugged in to the wall charger for at least 10 minutes before disconnecting
Dec 04, 2009 | Apple iPhone Smartphone
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Is it broken? Please help!
Hi it sound like you a problem called east west correction. But you will need to take it to a repair shop to fix it. My self i charge about £30 to fix this kind of fault. But dont know what others charg All the best Bob
Oct 17, 2007 | Bush 5693D 24" TV
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
