Question about LG WM-2277HW Front Load Washer
I have taken apart my drain pump but now i can't remember where the wires go on a lg front load washer
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
There are two connectors that attach to your drain pump, a black and a brown. They attach to the metal contact on the pump, it doesn't matter which one goes where, they are interchangeable.
When you put the front panel on, there is a door switch connector you need to attach before you put the screws back to hold it in place. After, the connectors on as you attach the top display portion of the washer. They are color coded, put the back into where the connector match with the size and colors on the main board.
Afterward, you can put everything back together and test the washer. Everything should light up and turn back on as normal before. Do not forget to put the particle filter trap back into the pump after everything is together on the bottom left corner of the washer or else it will leak lots of water when you do a wash.
Posted on Mar 20, 2011
Do I have to take apart the whole machine to fix the drain pump on my LG WM3455HW washer/dryer combo? I can't seem to find any instructions on this model.
Lucky You. The newer models of LG Combo units WM34xx have the filter on the right hand side and the pump can be changed through the bottom panel.
Nov 17, 2015 | LG Washing Machines
Does the pump make a funny sound when you have a clogged filter?
sometimes coins get stuck in the pump which causes noise when draining. Front of machine has to come off and pump taken apart and cleaned out.
Mar 02, 2015 | Frigidaire Affinity ATF7000E Front Load...
How to replace the drain boot on a maytag front load washer
I have taken many apart over the years, and I still refer to YouTube for advise.... Fixing a No-Drain Problem in a Front Load Washer http://youtu.be/b3kL3daLZ9g
Feb 24, 2015 | Maytag Neptune MAH5500B Front Load Washer
Amana front load washer how to clean water pump
remove the hoses and and remove the pump then use coat hanger to try to clean inside pump and try to turn propeller by hand depending on ur model some pumps cant be taken apart depending on either direct or belt driven ones
Aug 09, 2014 | Amana NFW7200TW 27-in. Washer Front...
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Will not drain pumps little water
Hello,remove the lower front panel....screws to remove are #19 and the panel #18 will drop down a bit and forward to come off.
sometimes coins,zippers,lint,bra under wires will get caught/jammed in the drain pump assembly and stop it from running/working.The hoses can be removed from the pump to check for any foreign objects or the
pump (the part where the pink and white wires are) can be totally removed by unclipping the wire harness and removing the two "5/6" bolts to check the pump assembly itself,The pump can be taken apart to check inside....if needed.The pump assembly is in the front right corner......
Thanks
May 24, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer won't drain! The OE message was on, I
have you cleaned out the water pump and hose ? check drain hose for blockage, check pump wiring to make sure it has a good connection.120 volts to pump. pump or board bad.
Feb 01, 2010 | LG WM-2277HW Front Load Washer
My washer does not drain the water, it is a front load washer. I have checked the pump already.
Noises - the original pump was a 40 watt pump, it often made a "howling" like noise. Replace the pump...the newer 80 watt pump has been more reliable.
Not draining - Front load washers are very bad for getting "junk" into the pumps...buttons, nails, zippers, bra wires....remove power and the front panel to access the drain pump assembly.
Remove power first! The pump is very easy to remove, ( unlocks from the base ) take the pump apart and check for foreign objects inside the pump assy. The power wires pull off and matters not which way they go back on. Also check the hoses to and from the drain pump for any  foreign objects. The pump is usually at the back right side ( looking at the washer from the front ).
for the diagrams click the link
http://www.applianceaid.com/neptune6.html
Mar 02, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Won't complete cycle
It sounds like your water pump is going bad or is bad.
Nov 08, 2008 | GE WCVH6260F Front Load Washer
LG WM-2277HW Front Load Washer Logo
109 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
