Question about Maytag MDBH955AWS Stainless Steel 24 in. Built-in Dishwasher
My Maytag dishwasher (MDB955AWS) will not drain ans is not cleaning the dishes properly.
  • 4,323 Answers
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Mar 19, 2011
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
It is just not cleaning the dishes. Runs - OK
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 24, 2011 | Maytag Jetclean II MDBH945AWS Stainless...
Have a real problem with etching,filming spotting not cleaning properly.Dishwasher 18 months old.Have tried all solutions as per manual,no joy.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Nov 11, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag dishwasher Model # DWC4910AAW SN A9830611KY Doesn't clean dishes anymore...leaves white soap (Cascade) residue on all; doesn't clean dishes anymore.
msbcox -- Check for residue in the strainer under the lower washbar. Remove the lower dish rack. Strainer is under washbar. Sounds like it is not draining properly. Write back if you need more help. -- SWT
Aug 04, 2010 | Maytag Dishwashers
Our Maytag quiet series 200 does not clean or rinse dishes properly. It leaves film all over cups and dishes. Water also seems not to be draining out. It is 6 years old
It is not the dishwasher. The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 07, 2009 | Maytag Dishwashers
My Maytag Performa recently stopped washing the food off the dishes. It fills and drains like it is supposed to, but seems to not have the right pressure.
Before drawing any serious conclusions check wash arms for blockage in spray holes, < possibly slowing delivery of water pressure > it can be calcium from hard water.
Apr 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Cleaning out dishwasher
Hi I checked the manual on line. Here's what it said.
Dishwasher has an odor
Run dishes being held in the dishwasher through a Rinse Only cycle.
• Many dishwashers have a “new” smell when first installed. This will dissipate with use.
• Dishwasher may not be draining properly. (See “Dishwasher Will Not Drain” section.)
• For a strong odor, place baking soda in both sides of the detergent cup. Select Light
Wash cycle and allow the water to circulate for about 10 minutes. Interrupt the cycle
by unlatching the door and let it stand overnight. Restart the dishwasher by latching
the door and allow it to complete the cycle. Another alternative is to use a dishwasher
cleaning product such as Jet-Dry Dishwasher Cleaner*.
Good Luck
Sep 17, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag MDBH955AWS Stainless Steel 24 in. Built-in Dishwasher Logo
334 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
