It was working ok until I disconnected the VCR & DVD player - now its saying there is no signal
    Sergeant:
  • 162 Answers
Make sure that you select the right input on your tv and switch your tv to the right input also.
Posted on Mar 19, 2011
My DVD says "root" on the screen. What do I do to get it to play?
"Root" is part of the Menu screen, press Menu on the remote to clear it.
Jun 05, 2010 | Philips Magnavox DVD/VCR Dual Player
Cant get both a VCR & DVD player to work on a SANYO TV, model # DS27590 cause there is no input button. The VCR works using a video button. Is it even possible???
Well if you could gain access to the inside if the set you could locate the Video's Composite Input, and there you could simply "Tap In" there, and run a Coax. OUT for the Video?DVD IN, and similarly, find the Audio's Input, and do the same for that. Then you could, simply NOT provide a signal, IE: Turn on & use, the VCR/DVD. And NOT supply a signal from the VCR/DVD. Instead supply the signal via YOUR leads, and it will NOT know the difference, and display what is being fed into it.
Mar 13, 2010 | Sanyo DS27590 TV
Can get dvd/vcr to work but vcr won't record
first did you program the vcr to match your cable channels ...that needs to be done on most vcrs/dvd/ combos and second if you have a cable box on your tv you still need to run a coax cable from the cable box to the in of the dvd player and out of the dvd player to the tv.
May 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Samsung dvd/vcr combo, dvd says "no signal," was working, vcr wor
On the remote, clicked a botton on the bottom. Don't have it with me so can't remember which one. Will look and post answer. Thanks
Dec 05, 2008 | Samsung DVD-V4600 DVD Player/VCR
Dvd loading
mine kinda has the same problem but it only happens with one movie Hairspray but it doesn't say error it just says loading for hours until i restart this system in order to get the DVD out. Need Help!!
Feb 16, 2008 | Sylvania SRD3900 DVD Player/VCR
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
How to set time and date
Turn on. Goto channel 3 or 4. Press DVD/VCR button until display says VCR. Press TV/VCR button until the display says VCR. Press SETUP button. Select SYSTEM SETUP. Select CLOCK SET. Edit time and date. Press SETUP button.
Jan 07, 2008 | Toshiba SD-V394 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
