Question about General Electric PVM1870 Microwave Oven
How do i access the fuse on a GE PVM1870 Spacemaker microwave and what does it look like
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
  • 3 Answers
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Posted on May 15, 2008
tiway1
  • 100 Answers
SOURCE: Need down loadable manual for PVM1870 DMCC GE Profile Spacemaker XL1800 over the range micro.
Follow this link to GE's manual download page and type in your model number ...
http://www.geappliances.com/service_and_support/literature/
Posted on Jun 30, 2008
SOURCE: GE spacemaker microwave stopped heating
I have a GE Over the oven microwave Model JVM1660BB. When heating it had started making a low humming noise. I could open the door and then close it, and the noise stopped. Now the oven won't heat at all. the light comes and the fan works. Jimbo
Posted on Apr 28, 2009
GE Microwave PVM1870 clean filter
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number here.
Jan 29, 2013 | General Electric PVM1870 Microwave Oven
Ge pvm1870 oven lights not on when microwave is working. is that normal?
the unit may be pulling too much current or power and will dim lights, usually an electrician can check this for you.
Feb 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hi! Our GE Spacemaker microwave (JVM241BL) stopped working..... nothing on it works at all. We have checked the breaker box in the basement and made sure it is plugged in. We are assuming it is a fuse...
Turn off the power before starting this process. If the oven is dead, the fuse is probably blown. Remove the two screws that hold the touch pad and control board in place to access the fuse. Once inside, look towards the back and follow the power cord that enters the rear of the microwave to the fuse. It should be a 15 amp ceramic fuse.
Dec 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the light that is inside the GE Spacemaker microwave?
with cord unplugged you can remove the main control panel and access to it
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE PVM1870 turntable not working
The little brown thing is broken. I have several break or melt. Pull it out and look at it.
Nov 18, 2009 | General Electric PVM1870 Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turns on but does not heat
if your microwave does not heat up when turned on its maybe the coil is burnt out are fuse broken, so check your dealers
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
yes there is. the fuse should be located behind the vent grill on the right side above the control panel. there may be a metal "grate" covering the access to it
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric PVM1870 Microwave Oven Logo
777 people viewed this question
Top General Microwave Ovens Experts
William Miller
William Miller
ken skalski
Steve Mason
Are you a General Microwave Oven Expert? Answer questions, earn points and help others
