Question about Samsung CLP-310N All-In-One Laser Printer
My printer says I have approx. 1/3 of all colours remaining. The right side of the printed page is faint and intermittent. The left side seems fine.
    Sergeant:
    Champion:
  • 236 Answers
Your fuser may be failing
Posted on Mar 19, 2011
White vertical band in Cyan and Black
try to clean the laserwindows of the printer.
Mar 25, 2013 | Xerox Phaser 6125 Laser Printer
Lexmark 4039 laser printer is printing left side of the page faint
check the cartridge it has a toner pcr and cylinder inside maybe its defective or the ic chips
Feb 19, 2013 | Lexmark 4039P 4039 Plus Laser Printer...
Left side is faint in colour than right side printing ,
u are running out of ink.
remove and shake the toner vigorously to evenly distribute the ink
it should print fine but consider replacement
Nov 27, 2011 | HP LaserJet 1020 Printer
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
I have a HP Colour LaserJet 2600n and am trying to find out how many pages I have printed on it since I got it 3 years ago. I also get the problem that the oage is covered with a faint blanket of toner....
You can print a configuration page using the control panel of the printer, it would have the option page count in that configuration page.
To print the Configuration page from the control panel
1. Press (LEFT ARROW) or (RIGHT ARROW) to select the Reports menu.
2. Press (SELECT).
3. Press (LEFT ARROW) or (RIGHT ARROW) to select Config Report.
4. Press (SELECT) to print the Configuration Report page
Page Counts. This section lists the total number of pages printed, the number of color
pages printed, and information about paper jams.
Sep 29, 2009 | HP Office Equipment & Supplies
1" stripe on rt side of page
First you make sure is not the toner cartridge causing the problem.
if toner cartridge was replaced and problems remain the same....
then you have a bad "FUSER ASSY"
Not very asy to replace by the regular USER....Need to take to a printer repair shop.
Jul 30, 2009 | HP LaserJet 3030 All-In-One Printer
Faint area down left side of page
When you say "Cleaned the lens" I presume you mean the four LED print heads. Use a spirit to clean them with if the toner dust is hard to remove. I usually just use a finger and wipe the entire length. Make sure there is no foreign item laying on the drum top where the black plastic film is as the led head may not seat properly on it. Clean all the silver high voltage springs down the left side of the printer. They make contact with the drums. If you still have a problem then try printing solid colour blocks ie Yellow, Magenta ,Cyan and Black . This will identify which colour is giving the problem . Change that drum and all should be well.
Jul 26, 2017 | OKI C3400n Laser Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
Very faint printing in xerox 3117 laser printer
my ml 2010 never has printed as dark in the centre of the page even when the toner is full?
Sep 02, 2008 | Samsung ML 2010 Laser Printer
Samsung CLP-310N All-In-One Laser Printer Logo
59 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
