Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool front panel dead but cooling
Hi, I own a 2yr old Side by side Whirlpool gold model GS6NBEXRS00. The unit seems to be cooling, but now the front panel is dead. No lights or anything. also the inside LED display for ref/freezer temp settings go out after about 1-2 minutes after plugging the fridge back into the wall.
Here's what happened to case this: I had the front panel off to work on the ice dispenser motor. To get to the motor, I had removed the Dispenser Core Control board (behind the front panel). I plugged it back in and all worked, except I didn't have the board set in the right place, so i unhooked once again to get the mounting tabs alighed When I reinstalled the second time, I believe I reveresed plug 6 and plug 7 (since they are the same 3 prong plug right next to eachother). Then nothing worked on the front panel. I unplugged the fridge and realized what I had done, so I plugged up P6 & 7 correctly, let the unit sit for about 10 minute, and plugged back in. Now it cools, but nothing works on the front panel. did I mess up something in the Dispenser Core Control board? Thanks for any help!
Just had mine done exactly the same repair175 quid plus labour
Posted on Jan 31, 2013
  • 61 Answers
Whirlpool gold refrigerator electronics for icemaker and water are dead
Moisture damage or bad connection. Take apart and check wires and circuit board.
Jul 24, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Whirlpool ED5VHGXM Side by Side...
Water in bottom try more than can be evaporated by fan pan overflowing Model Gs6nbexrs00 Serial ss2448296 4 1/2 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check the door seals...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Model GS5SHA Side by side. Freezer working, refrigerator side not getting cold.
heatman101
Sep 06, 2010 | Whirlpool Refrigerators
Whirlpool Gold GD5SHAXLQ02- Serial number SP3131657 just stopped cooling. Neither the fridge and freezer seems to be cooling. This unitl is about 7 years old.
Hi!!
Check
temp. control knobs,
Small fan in freezer
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear. Once this is done, restart unit.
If evaporator is not covered w/ice, then you may have a freon leak, Call a Service Center to get a repair estimate.
Don't forget to rate this post!! Good Luck
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Front ice/water despensor not working
Try looking for a child safety switch that can sometimes be found hidden up in the dispenser, depending on the model. It will be a switch that looks like it doesn't do anything.
If this can't be found then you may have a wiring problem which would require a service call.
Nov 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge not cooling 60 degrees
hi thanks for the question did you clean the coils at the back by the compressor if not clean the coils its very important try that thanks the appliance doc
Sep 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
May 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Oven door locked and dead panel
TRY UNPLUGGIN THE RANGE FOR FIVE MINUTES AND THEN PLUGGING IT BACK IN. IF IT DOESN'T RESET AND UNLOCK, YOU COULD HAVE EITHER A BAD OVEN SENSOR OR BAD CONTROL(CLOCK). IF YOU ARE A DO IT YOURSELFER, YOU COULD BUY A NEW OVEN SENSOR, REMOVE THE BACK PANEL FROM THE RANGE(THE LARGER LOWER PANEL) FIND THE SMALL CONNECTOR PLUG THAT COMES THROUGH THE BACK WALL. IT HAS ONLY TWO WIRES ATTACHED TO IT. DISCONNECT THE OLD SENSOR AT THAT POINT AND CONNECT THE NEW SENSOR. IF THE OLD SENSOR IS BAD, THE DOOR WILL UNLOCK AND YOU CAN THEN REPLACE THE BAD SENSOR
THROUGH THE OVEN OPENING.
Apr 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
265 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
